[GAMBIT] gambit error limited!!!
Like Tree4Likes
Old   May 25, 2011, 11:20
Default gambit error limited!!!
stage81 is on a distinguished road
Hii,
I would like to know does the mesh of GAMBIT is limited? because when i meshed the domain I get the folloming error :
ERROR: Unable to write 32505856 bytes of data to descriptor 8.
-Instead -1 bytes were written
mesh of volume contains 8000000 highly skwed elements
Thanks for your help
stage81 is offline   Reply With Quote
Old   May 27, 2011, 03:10
-mAx-'s Avatar
Maxime Perelli
-mAx- will become famous soon enough
decompose your domain into subdomains (splits)
stage81 likes this.
In memory of my friend Hervé: CFD engineer & freerider
-mAx- is offline   Reply With Quote
Old   May 27, 2011, 04:32
Can you show me how i can decompose my domain (brick 3D)?? thanks
Old   May 27, 2011, 04:58
-mAx-'s Avatar
Maxime Perelli
show me your domain
Old   May 27, 2011, 05:08
My domain is a brick3D: [2cm, 1cm, 1cm], and i want to mesh this domain with an interval size of 0.005 along the x, y and z directions,
show me your domain
Old   May 27, 2011, 05:19
-mAx-'s Avatar
Maxime Perelli
like that for instance
stage81 likes this.
Old   May 27, 2011, 08:29
Can you sent me this in form ".msh" plaise
Attachment 7839
Old   May 27, 2011, 08:36
-mAx-'s Avatar
Maxime Perelli
There is no mesh. It is only the volume decomposition.
I advice you to do it yourself, but I give you the journal file...
volume create width 2 depth 1 height 1 brick
face cmove "face.3" multiple 1 offset 1 0 0
face cmove "face.1" multiple 1 offset 0 0 0.5
face cmove "face.2" multiple 1 offset 0 0.5 0
volume split "volume.1" faces "face.9" connected
volume split "volume.1" faces "face.8" connected keeptool
volume split "volume.2" faces "face.8" connected
volume split "volume.3" faces "face.7" connected keeptool
volume split "volume.1" faces "face.7" connected keeptool
volume split "volume.2" faces "face.7" connected keeptool
volume split "volume.4" faces "face.7" connected
Old   May 27, 2011, 08:53
Ok thanks, i'll test this journal file
Old   May 27, 2011, 22:25
PSYMN's Avatar
Simon Pereira
PSYMN has a spectacular aura aboutPSYMN has a spectacular aura about
Also, are you 32 bit or 64 bit...
You are not going to get 32 million cells out of 32 bit Gambit...
(the 32 million was just a coincidence... nothing to do with 32 bit... I don't think you could get 15 million cells out of 32 bit gambit...)
Please help guide development at ANSYS by filling in these surveys
Public ANSYS ICEM CFD Users Survey
This second one is more general (Gambit, TGrid and ANSYS Meshing users welcome)...
CFD Online Users Survey
PSYMN is offline   Reply With Quote
Old   May 30, 2011, 03:48
I m 32 bit not 64
Old   June 1, 2011, 01:45
-mAx-'s Avatar
Maxime Perelli
I managed to get a 10 million cells mesh on 32 bit version.
No problem untill I wanted to export the mesh.
That's the problem..
I had to switch on linux64 bit partition with 8GB Ram. Then problem has been fixed
Old   June 1, 2011, 09:54
I also get the problem when I export the mesh .. Luckily for you I have note Linux 64! i have the 32bits (windows and linux)
Thanks for information MAX
Old   October 9, 2012, 07:43
Default related problem
  #14
Rustam
Rustam is on a distinguished road
I use 64 bit linux version of Gambit 2.3.16.
I manage to create a big mesh, say, more than 12-13 mln, but the error occurs when I try to convert it to .neu. And I use this format further with some in-house code.
After completing meshing it starts to write the Neutral file, for example:
"Writing 14046777nodes, 13600000 elements, 1 group and 0 bc sets to GAMBIT Neutral file test_new.neu.
ERROR: Error writing to file at line 38008498
/ Closing readfile ..." etc
In the next message I attach a .jou file. You can run it from the command line as follows
gambit -inp name.jou
although I use alias:
alias gambit='FLUENT_ARCH=lnx86 gambit -x11'
I would be happy to any help since I fill uncomfortable to switch to another meshing tool.
Thank you for help.
Rustam
Rustam is offline   Reply With Quote
Old   October 9, 2012, 07:44
Rustam
It is not very clean though
Journal File for GAMBIT 2.3.16, Database 2.3.14, lnx86 SP2006033020
/ Identifier "default_id"
/ File opened for write Thu Oct 7 10:45:59 2010.
volume create width 1 depth 1 height 1 brick
undo begingroup
edge picklink "edge.4" "edge.12" "edge.1" "edge.9"
edge mesh "edge.9" "edge.1" "edge.12" "edge.4" successive ratio1 1 intervals \
100
undo endgroup
undo begingroup
edge picklink "edge.8" "edge.7" "edge.5" "edge.6"
edge mesh "edge.6" "edge.5" "edge.7" "edge.8" successive ratio1 1 intervals \
100
undo endgroup
undo begingroup
edge picklink "edge.3" "edge.2" "edge.10" "edge.11"
edge mesh "edge.11" "edge.10" "edge.2" "edge.3" successive ratio1 1 intervals \
80
undo endgroup
volume mesh "volume.1" map size 1
volume cmove "volume.1" multiple 16 unlinkmesh offset 0 0 1
solver select "Generic"
export gambit "test_new.neu"
Old   October 9, 2012, 09:36
-mAx-'s Avatar
Maxime Perelli
No problem for me to export your *.neu file
It generates a 2.3GB file
PS: I generates it from GUI >> File/Run Journal...
Old   October 9, 2012, 10:17
Rustam
Thanks for spending your time, -mAx-.
Than i have another question. Where did you download your gambit? is it legal?
Because I use a cracked one. Which version do you have?
Thanks again
Rustam
Old   October 10, 2012, 01:06
-mAx-'s Avatar
Maxime Perelli
I have legal license (2.4.6)
Old   October 10, 2012, 05:50
Tamil Nadu
nkme2007 is on a distinguished road
Hello All,
I want to do analysis of heat transfer from water flowing through pipes submerged inside concrete. I am modelling in GAMBIT and wish to analyse it on Ansys FLUENT.
Can anybody help me out, how to model and simulate?
Does any tutorials exist?
nkme2007 is offline   Reply With Quote
Old   October 10, 2012, 12:17
You cas see this exemple,
http://fr.scribd.com/doc/49980814/47...luent-Training
PSYMN likes this.
Gambit Startup Window Jay Shim FLUENT 2 February 12, 2015 14:05
Gambit help: Cube inside cube Jack Martinez FLUENT 13 August 11, 2010 06:29
Gambit 2.3.16, Xming or Exceed...HELP! bambam3417 FLUENT 10 May 7, 2010 12:39
Gambit -dev X11 doesn't work Ervin Amet FLUENT 0 October 28, 2007 08:33
Generating big meshes with GAMBIT on NT Andrew Ooi FLUENT 12 February 2, 2000 22:26
