Pro/e to cfx geometry filler
Old   May 30, 2011, 23:23
Default Pro/e to cfx geometry filler
James McLachlan
Jmac is on a distinguished road
I am undertaking a cfd analysis of a fairly complex shower mixer component. I have a CAD model of the component itself in pro/engineer but what I require is a model of the internal cavities (where the fluid is flowing through) that can be used for a cfd analysis. Due to the complexity of the part it is not possible to create this from scratch in design modeller or otherwise. Is there a feature on ANSYS or pro/engineer that I can use to create the cfd geometry?
Any help would be appreciated,
thanks
Jmac is offline   Reply With Quote
Old   June 6, 2011, 14:41
PSYMN's Avatar
Simon Pereira
In ANSYS Meshing, you would want to extract a flow volume... It basically does a boolean subtraction.
In ICEM CFD, you would just place a material point inside and close the inlets and outlets... ICEM CFD is a surface based modeler and doesn't need to do a boolean, you just say which volumes you want meshed...
If you can be more specific about which tool you are using, we can give more specific instructions.
CFD Online Users Survey
Old   June 23, 2011, 19:33
James McLachlan
I'm using pro/engineer to transfer to ANSYS CFX
Old   June 24, 2011, 12:03
PSYMN's Avatar
Simon Pereira
No, I meant what meshing tool are you using...?
If the answer is ANSYS Meshing, then you could do a flow volume extraction...
ansys, geometry, pro/e
help simplify geometry for CFX denjil ANSYS Meshing & Geometry 0 March 28, 2010 05:27
PhD using CFX Rui CFX 9 May 28, 2007 05:59
CFX Post - Inserting additional geometry Andrew CFX 2 April 18, 2007 08:27
Geometry and meshing with CFX Bob Crad CFX 3 January 7, 2004 12:56
CFX 4.4 installation problem Pandu Sattvika CFX 1 December 1, 2001 04:07
