[ANSYS Meshing] Meshing very simple body (steel container)
Old   October 3, 2019, 16:58
Default Meshing very simple body (steel container)
Valaki Valami
woodwax is on a distinguished road
Hello
I would like to mesh this very simple body. Its a steel barel with 0.6 mm walls. I always get an error:
"A mesh could not be generated using the current meshing options and settings." and "The meshing has completed, but some elements are not compliant with the applied shape checking criteria."
Here is the project with my settings: https://drive.google.com/drive/folde...7w?usp=sharing
I hope somebody can help me, maybe its just a few minutes. Thank you!
woodwax is offline   Reply With Quote
container, cylinder, mesh
[ANSYS Meshing] Meshing a faceted body egge24 ANSYS Meshing & Geometry 0 March 12, 2019 12:47
[ICEM] Need advice with meshing of conical body badboyz31 ANSYS Meshing & Geometry 3 December 9, 2016 07:05
simple 2D rotating disk-with rigid body dyson CFX 2 June 25, 2016 02:53
[ICEM] Meshing Multi Solid Body for CFD marauder ANSYS Meshing & Geometry 0 March 18, 2015 06:32
[ANSYS Meshing] Meshing a fluid NOT as a surface body Soph ANSYS Meshing & Geometry 2 February 9, 2012 11:29
