[ICEM] Open channel flow
Old   June 15, 2011, 12:04
Default Open channel flow
mchith
mchith is on a distinguished road
Good day everyone,
So I started working on my model which is basically a channel with one cylinder in the middle, for the begining i am just putting one to get the basic idea of the software.
Anyway, i did the geometry, the blocking and splitting the blocks, i then tried to do the association of edges with curves and i computed the pre-mesh, but i have noooo idea what i got, i couldnt even see the mesh around the cylinder, can you please tell me what steps i might have missed or what i should do?
i attached the project and some images
thank you very much
mchith is offline   Reply With Quote
Old   June 16, 2011, 04:36
jeevan kumar
jeevankumarb is on a distinguished road
Your blocking doesnt have edges associated to curves and also there is no bunching set for edges in order to have some cells to view.
Associate edges to curves and set some bunching on the edges.
Regards
jeevan
jeevankumarb is offline   Reply With Quote
Old   June 16, 2011, 09:09
mchith
hey
okay so i have the cylinder in the middle of the channel, so i split the blocks and then i had to collapse the blocks for the cylinder so i didnt know which ones to collapse... there is one ot top of it runnning from the outlet to the inlet but not passing through it, and there are two either side of the cylinder (and those are the ones i collapse, but when i did that i found that the block went crazy...i attached the file so tell me what you think,,i still didnt do the mesh params and nodes and all that...
thank you
Old   June 17, 2011, 06:35
jeevan kumar
I will have a look at it.
i have made some modifications to the blocking. I have uploaded the blocking file, it might be helpful for you. try to build a similar one.
regards
jeevan
Old   June 17, 2011, 10:31
mchith
hey jeevan thank you for sending me the file..looks great really. can you lead me through the steps you did..i mean the one i did didnt look anything likt that and from what you saw you must have guessed that i have no experience. what i did was i followed similar steps to the pipe blade tutorial..also a little from the wing body tutorial. i see that you made several splits in the channel where as i left them as to blocks on either side.. and for the cylinder did you collapse the blocks??also the block over the cylinder looks really good in the model you made i wasnt able to do that, as when i collaped the bloacks under it, it changed into a triangular shape. I am greatful for you help
Old   June 17, 2011, 10:37
mchith
and in the blocks you made...how would you associate the edges to the cylinder curves???
thanks
Old   June 17, 2011, 11:31
mchith
hey tell me what you think.....now what do i do to take it to fluent :P i have no idea
Old   June 17, 2011, 15:48
mchith
HEY AGAIN
i made this new geometry and i have 2 cylinders. they both share thet same vertice at one point and i dont know how to solve that i attached an image..i can only associate it to one of the cylinders
Old   June 20, 2011, 10:26
mchith
please guys tell me what you think of this and if i can do it in any other way
cheers
Old   June 27, 2011, 03:11
jeevan kumar
no tetin file and blcking file???
Open channel flow motaba Main CFD Forum 4 March 26, 2011 03:22
Open Channel Flow OffshoreStructuralEnginer CFX 13 August 3, 2010 21:31
Problem installing on Ubuntu 9.10 -> 'Cannot open : No such file or directory' mfiandor OpenFOAM Installation 2 January 25, 2010 09:50
pressure outlet (open channel flow) Willem Brantegem Main CFD Forum 0 April 3, 2007 09:39
Open Channel flow Boundary khalid FLUENT 1 November 4, 2006 11:53
