[ANSYS Meshing] Meshing a 3D Airfoil
Old   July 14, 2011, 04:03
Default Meshing a 3D Airfoil
Lloyd Moffatt
lloydmof is on a distinguished road
I am attempting to model a simple 3D airfoil in ANSYS, with the aim of accurately estimating the form and induced drag. This means, there would need to be sufficient refinement around the end of the wing where vortices are generated, and also the boundary layer of the entire foil section.
How should I best go about achieving a high quality mesh around this object? I was considering an Inflation from the surface and sphere of influence around the end of the wing. This is currently failing to mesh with the following error:
The following non sweepable bodies have force sweep method controls and cannot be swept:
The following body cannot be swept with the specified source and target faces. Pick a different pair of source and target faces and try again:
Any ideas?
LM
lloydmof is offline   Reply With Quote
Old   October 30, 2016, 06:43
Aseel
Ad.Al.Qads is on a distinguished road
I am facing the same problems and i don;t know how to fix them.
could anyone help me solve this issues ??
thank you
Ad.Al.Qads is offline   Reply With Quote
Old   November 4, 2016, 07:58
Gweher's Avatar
Gwenael H.
Gweher will become famous soon enough
This is a well-documented problem so you should have a look on the forum on how to mesh a 3D airfoil, there are even tutorials on the Ansys youtube channel.
Gweher is offline   Reply With Quote
Old   November 4, 2016, 10:02
Aseel
Hey
i faced the same problem while i am doing ice cold flow simulation?
it was in the valve body ? any idea how to fix this issues ?
thank you
foil meshing inflation
Airfoil Meshing Scheme in Gambit J. Weiler FLUENT 6 October 2, 2011 15:41
[Other] Ansys meshing airfoil and / or compressor blades baw192 ANSYS Meshing & Geometry 8 September 23, 2011 00:43
Gambit - meshing over airfoil wrapping (?) problem JFDC FLUENT 1 July 11, 2011 05:59
Oscillating Airfoil - Dynamic meshing or user-defined velocity profile. DarrenC Main CFD Forum 5 July 19, 2010 22:33
[GAMBIT] Meshing airfoil using .dat file problem creggie ANSYS Meshing & Geometry 10 June 27, 2010 19:24
