[GAMBIT] 3D pipe o-grid GAMBIT
Old   July 22, 2011, 07:31
Default 3D pipe o-grid GAMBIT
salzferkel is on a distinguished road
i've try to make o-grid circular mesh on pipe 3-d. tried many times since yesterday didn't work.
now my idea, i make a face circle, and i have to split it into 8 pieces each @45°
how to split the circle face into 8 pieces faces @45°
how to do this on gambit ??
many thanks for help.
salzferkel
salzferkel is offline   Reply With Quote
Old   July 22, 2011, 07:50
-mAx-'s Avatar
Maxime Perelli
-mAx- will become famous soon enough
post a sketch of what you want
In memory of my friend Hervé: CFD engineer & freerider
-mAx- is offline   Reply With Quote
Old   July 22, 2011, 07:52
thanks max.
here the pic
regards
Old   July 22, 2011, 08:01
-mAx-'s Avatar
Maxime Perelli
on your picture you have a coax cylinder (one small cylinder hollow)
Old   July 22, 2011, 08:13
Attachment 8518
hi max,
yeahhh this is my problem.
i can make the one that in the middle hollow. i creat the mapped mesh on the outer face of cylinder, then submapped mesh on the face, circle ( inlet ) afterthat then i say to gambit should make the whole pipe (volume meshing) .. i've got as attached. it looks not good as in the hollow
should i just leave it hollow for the computation ? because it should a full cylinder.
attached the one i did now
Old   July 22, 2011, 08:24
-mAx-'s Avatar
Maxime Perelli
Instead of a circle in the middle, create a square, then split the surface which surrounds the square into 4 sub-surfaces (see picture).
Mesh the square first, then the other.
Old   July 22, 2011, 08:40
Attachment 8520
alright, how can i split the surface that surrounds the square into 4 sub-surfaces in gambit ?
thanks
Old   July 22, 2011, 08:43
-mAx-'s Avatar
Maxime Perelli
create your vertex on the circle (with split edge for instance)
Then split surface with vertex: select one square corner and the appropriate vertex on the circle (it will split the surface with a line)
etc..
Old   July 22, 2011, 09:32
etc..
thanks a lot max.
i've splitted the surface and the square as order.
now i try to mesh, if i starting from the surface square as map, then the surface circle ( see attached) gambit offer only pave option. i mean, if i switch to map mesh, it didn't work.
if i starting meshing from surface of the contour of the cylinder, then the the (inlet ) splitted surface (circle and square)
i got the mesh not as circular. see attached pic 2.
im sorry, im quite new with gambit.
thanks lot
Old   July 22, 2011, 09:41
-mAx-'s Avatar
Maxime Perelli
split also volumes:
split full pipe, with square-section-pipe
Then split volume surrounding the square-section-pipe with planes which will generate 4 sub-volumes.
Old   July 22, 2011, 11:12
split also volumes:
thanks lot max.
but i got problem with splitting the volumen. it didint work. gambit said, it has a non volumen geometry. i try to comprehend.
i created 4 vertex alongside surface circle. then split surface with the square.
i found when i splitted the surface circle with the square with vertices ---> virtuell. (see attached) and the face change to non geometrical face. it means virtuelle surface ?? not real geometry
i dont know what i did wrong with splitting.
Old   July 22, 2011, 14:23
Hi Max...
finally i find the way!
well i get your idea to split the surface. but seems when i the circle edge splitted , seems the circle has got distorsion ,and the end of the vertex to another part of the surface didnt joint together.
now i didnt create the square in the middle. i just make the circle surface. then spitted into 4 quadrant.
when i click the mesh on the face, it marked a pizza slice orthogonal.
i've got not much experience, but i think the meshing now quiet good for computing. see attached.
what do you think ? is that enough to a good circular meshing for computing ?
thanks lot for helping.
finally i know how to split the surface. so now i made the version square with circle. (see attached) it also works.
many thanks Max!
Old   July 24, 2011, 01:54
Default extrude in Gambit
  #13
s.rasoul_varedi
desert_1250 is an unknown quantity at this point
Send a message via Yahoo to desert_1250
can any body tell me :
how can i extrude airfoil in Z dir by using GAMBIT?
tanx
___________
rasoul
desert_1250 is offline   Reply With Quote
Old   July 25, 2011, 09:48
-mAx-'s Avatar
Maxime Perelli
tanx
___________
rasoul
sweep surfaces, and choose vector option
Old   July 25, 2011, 09:51
-mAx-'s Avatar
Maxime Perelli
There is no only one way to mesh a domain.
You can mesh with hexa, tetra, wedge, hybrid, coarse, fine, etc...
Old   July 25, 2011, 10:19
s.rasoul_varedi
tanx max for your quick reply, i will try it ASAP, but would you tell me how can i see velocity or pressure contour for inside of the 3d geometry. on the othe hand i wanna eliminate or pale all bondaries to see what happen in it after run and see any contours. i dont want to use clip or slice or etc
tanx
___________
Rasoul
Old   July 25, 2011, 10:54
-mAx-'s Avatar
Maxime Perelli
if you don't want to use clip, sweep etc... then there are path lines.
Old   July 25, 2011, 23:47
s.rasoul_varedi
how to get path line!!!?
____________
Rasoul
Old   July 26, 2011, 03:37
-mAx-'s Avatar
Maxime Perelli
____________
Rasoul
http://my.fit.edu/itresources/manual...tg/node357.htm
Old   July 26, 2011, 04:15
s.rasoul_varedi
tanx but i use OpenFOAM software not Fluent, how did it in OpenFOAM??
_______
Rasoul
"real" structured grid by gambit zonexo FLUENT 0 May 18, 2006 12:11
Unstructured grid problem - Laminar flow pipe Roby FLUENT 0 January 12, 2006 05:54
Different grid spacing in Gambit - Fluent Vasilis X FLUENT 1 November 8, 2005 04:22
Gambit pyramid grid Frank FLUENT 2 July 28, 2003 04:59
Combustion Convergence problems Art Stretton Phoenics 5 April 2, 2002 05:59
