Double pipe heat exchanger
Old   August 18, 2011, 07:09
Default Double pipe heat exchanger
Mohsin
mohcin is on a distinguished road
I am trying to model a double pipe heat exchanger but whenever I try to mesh that model there is an error comes up as ' mesh exporter does not support overlapping geometry problem'. I dont know how to resolve this issue. Kindly help to resolve this issue.
Regards,
Mohsin
mohcin is offline   Reply With Quote
Old   August 18, 2011, 07:48
-mAx-'s Avatar
Maxime Perelli
-mAx- will become famous soon enough
post picture
In memory of my friend Hervé: CFD engineer & freerider
-mAx- is offline   Reply With Quote
Old   August 18, 2011, 10:04
Mohsin
I have solved that problem for the model in which both the fluids are water but if I used the model like :
Inner fluid = hot water
Inner pipe = copper
outer fluid = Phase change material (solid)
outer pipe = copper
then it gives errors like Access Violation?
Thanx
Regards
mohsin
Old   August 18, 2011, 10:12
Anjaneyulu Nanduri
anjan is on a distinguished road
[QUOTE=mohcin;320604]Hi,
hi, it is a double domain channel, so 2 domains are necessary for flowing, first create a geometry a pipe in pipe, import that cad file into icem, declare all fields, inlet_1,outlet_1, inlet_2, outlet_2. first take a material point in inner pipe mesh it, and take another point and mesh it next.
anjan is offline   Reply With Quote
Double pipe heat exchanger mohcin FLUENT 21 June 18, 2016 14:19
Continuing User Defined Real Gas Model issues aeroman FLUENT 6 April 8, 2016 03:34
how to analysis double pipe heat exchanger in cfx rammax8 CFX 12 February 14, 2014 16:10
Missing math.h header Travis FLUENT 4 January 15, 2009 11:48
REAL GAS UDF brian FLUENT 6 September 11, 2006 08:23
