[ICEM] mesh several bifurcations-blocks
Old   August 23, 2011, 05:16
Default mesh several bifurcations-blocks
Lilly is on a distinguished road
Dear all,
I have got a general problem with hexa-meshing of my geometry. My geometry has several bifurcations and branch-offs and I want to generate an O-grid for it. But at the moment I am not able to find the correct position of the blocks. I already got an advice how to place the blocks for my first bifurcation (thank you, Timothy!), but for any reason my mesh looks still strange, especially at the bifurcations.
Furthermore, I already moved the vertices of the blocks several times, but the resulting grid always contains a lot of negative volumes and degenerated elements and smoothing doesn't help at all. I am afraid that's a problem due to my general way of how I position the blocks (normal and o-grid) and my way of meshing .
Does anybody can give me an advice or maybe recommend a good tutorial for this problem (I couldn't find one which helps me dealing with this special problem)?
Thanks a million in advance!
Lilly
Lilly is offline   Reply With Quote
Old   August 23, 2011, 05:41
AB
BrolY will become famous soon enough
Associate the edges to the curves.
BrolY is offline   Reply With Quote
Old   August 23, 2011, 05:54
Thank you, BrolY!
I did this for the inlet and outlets. Do you mean I should try to create further curves at the bifurcation and do the association there too?
Old   August 23, 2011, 07:29
AB
Yes, do the association for each bifurcation !
[snappyHexMesh] SnappyHexMesh for internal Flow vishwa OpenFOAM Meshing & Mesh Conversion 24 June 27, 2016 08:54
[ICEM] surface mesh merging problem everest ANSYS Meshing & Geometry 44 April 14, 2016 06:41
[Gmsh] 2D Mesh Generation Tutorial for GMSH aeroslacker OpenFOAM Meshing & Mesh Conversion 12 January 19, 2012 03:52
[ICEM] connected mesh in blocks joint gajemon ANSYS Meshing & Geometry 6 December 17, 2009 16:31
basic of mesh refinement arya CFX 4 June 19, 2007 12:21
