Inflation Mesh Possible with Multizone Method for this Geometry
Like Tree3Likes
  • 3 Post By PSYMN
Old   September 6, 2011, 13:37
Default Inflation Mesh Possible with Multizone Method for this Geometry
jonathan
jonny_b is on a distinguished road
I am currently trying to mesh a complex goemetry using the Multizone mesh method in ANSYS Meshing and am having difficulty applying a pre-inflation layer to the geometry. From the documentation I've read, an inflation layer using the Multizone mesh method is really just an O-grid tool (or so I have interpreted). I've attached an image of the geometry I am meshing. The red surfaces are the surfaces I am attempting to apply an inflation layer too. Is the geometry to complex for an inflation layer?
Thanks
jonny_b is offline   Reply With Quote
Old   September 8, 2011, 17:09
PSYMN's Avatar
Simon Pereira
PSYMN has a spectacular aura aboutPSYMN has a spectacular aura about
It should be doable, but perhaps it is failing due to the small lip area... At the very least, that should limit your max boundary layer thickness to less than half that feature size...
I will contact you privately to see if we can get this model in for testing.
Best regards,
Simon
Please help guide development at ANSYS by filling in these surveys
Public ANSYS ICEM CFD Users Survey
This second one is more general (Gambit, TGrid and ANSYS Meshing users welcome)...
CFD Online Users Survey
PSYMN is offline   Reply With Quote
Old   September 16, 2011, 16:20
Default Too many layers...
PSYMN's Avatar
Simon Pereira
Thanks for sending the model, and I confirm my original guess... If you reduce the number of inflation layers to <=22, the meshing works.
The problem is that once the layers get larger they will overlap (see picture attached and imagine another layer in this area of red dot), and the meshing will fail.
I agree we need to improve the messaging/behavior to handle overlapping inflation layers, but right now, you need to control this via setting appropriate number of layers. In an ideal world, we could auto-reduce the Ogrid height locally or split off the tricky region behind the Ogrid. It is just a matter of getting to those sorts of requests in the Queue, but I forwarded your model to development for their consideration...
There may be other things you could try, such as splitting the geometry or setting smaller heights in that area so you could fit in the 50 layers... You could play with those options...
jonny_b, DungPham and sharonyue like this.
[Other] Mesh to Geometry / Mesh to solid denner OpenFOAM Meshing & Mesh Conversion 0 June 4, 2009 12:44
Convergence moving mesh lr103476 OpenFOAM Running, Solving & CFD 30 November 19, 2007 14:09
Complex Mesh In Gambit. Ranjeet Main CFD Forum 9 April 29, 1999 17:18
unstructured vs. structured grids Frank Muldoon Main CFD Forum 1 January 5, 1999 10:09
