[DesignModeler] Import Geometry Dimensions
Old   October 1, 2011, 13:58
Default Import Geometry Dimensions
Febin
Febin is on a distinguished road
I am trying to find the Coefficient of lift and drag of a UAV. The UAV was designed in Ansys Classic version. Now, when I imported the geometry into Ansys Designmodeler, the dimensions are found to be too small. For e.g, the length of fuselage was set as 1.81m while creating the model. But, in designmodeler, it is just .0475m. How do I keep the original dimensions?
Thanks!!!
Febin is offline   Reply With Quote
Old   October 2, 2011, 22:30
Default Just scale it...
PSYMN's Avatar
Simon Pereira
PSYMN has a spectacular aura aboutPSYMN has a spectacular aura about
This could be some sort of units mismatch... I divided one by other expecting it to fall out as some common number like 25.4 (mm/inch). Instead it was 38.1, so I am not sure if you just were not specific enough about what had become what...
But either way, the solution is just to scale the model after it is in DM... Find the exact ratio between the models and scale it appropriately...
I think the option is under the create tab, but just check the help for "scale" and do what ever factor you need to get the job done.
Please help guide development at ANSYS by filling in these surveys
Public ANSYS ICEM CFD Users Survey
This second one is more general (Gambit, TGrid and ANSYS Meshing users welcome)...
CFD Online Users Survey
PSYMN is offline   Reply With Quote
Old   October 4, 2011, 14:35
Febin
Thank you Simon. As you said, scaling was what needed to be done!!!
Import geometry from CAD Giuseppe (Giuseppe) OpenFOAM Pre-Processing 34 December 14, 2017 16:24
Access dimensions of model geometry cp_jef Fluent UDF and Scheme Programming 2 August 1, 2011 01:11
Import Geometry Gambit Henri79 ANSYS Meshing & Geometry 0 May 7, 2010 02:44
vitual _ real deneb FLUENT 3 January 22, 2007 04:31
Multiple import of Geometry in GAMBIT(Catcon Simu) Amod kumar FLUENT 0 July 21, 2006 23:55
