[ANSYS Meshing] Problem in updating the mesh in Workbench |
May 27, 2016, 08:16 |
#21 |
Lukasz
If I good understand, this problem is because you used wrong name of file. In my opinion is three ways. You used to long name, you used non English letters for name of file or for name of folder or disc. For example: ę ś ć ń ó ł or something like that.
July 19, 2016, 08:01 |
#22 |
Ramin
Rep Power: 10 |
hi everyone
I had this problem in my project and I didn't find any answer for a long time after that I have found that this error occur in 2 case: 1-the model that you use for meshing is not sufficient for example: in "Face Sizing"-->the behavior should not be hard. this error was due to match control that I had used and without match control I did not have any problem. 2-the sizing that you apply is not good for example if you choose to have 0.3m size for meshes around a circle in "face Sizing"...and you choose to have another control over this circle with "body sizing"that surrounded this circle,the sizing that you apply for this section should be lower than 0.3m this was my experience in 3D meshing. maybe another case is changing the name of your files if they have special character. Best Regards, Ramin |
December 19, 2016, 00:43 |
#23 |
Andreas Sun
Rep Power: 13 |
Same problem as you, thank for your tip.
solved my problem. |
October 31, 2017, 02:52 |
#24 | |
naman doshi
Rep Power: 8 |
I TRIED USING THIS the model that you use for meshing is not sufficient for example: in "Face Sizing"-->the behavior should not be hard. this error was due to match control that I had used and without match control I did not have any problem. SOLUTION AND IT WORED THANKS |
ansys 13, error, fluent, mesher |
3D Hybrid Mesh Errors | DarrenC | ANSYS Meshing & Geometry | 11 | August 5, 2013 06:42 |
Some questions about mesh updating in dynamic mesh technique | lzgwhy | Main CFD Forum | 0 | June 14, 2009 08:01 |
fluent add additional zones for the mesh file | SSL | FLUENT | 2 | January 26, 2008 11:55 |
Problem with Output to .cfx5 mesh | Ben | CFX | 4 | January 24, 2008 17:47 |
How to control Minximum mesh space? | hung | FLUENT | 7 | April 18, 2005 09:38 |
