[ICEM] Using Blocking with ICEM (infinity lines appear) |
October 11, 2011, 21:44 |
Guiliguili
I am trying to mesh with ICEM a domain of a flow over a backward facing step but it doesn't work using Blocking. When I use Blocking my 2D domain is not closed. The upper and lower blocking lines continue on the right and left sides to infinity ??? The simple geometry is below. I think that it is an environment setting problem but I don't know which one. Any suggestions. Last edited by Touré; October 13, 2011 at 15:17. |
October 11, 2011, 22:50 |
KJ Lee
I don't think that should be happening as long as you haven't changed the default settings on ICEM. Have you tried checking the 2D blocking mark in the blocking menu or manually highlighting the entities you are trying to block?
October 12, 2011, 23:09 |
Guiliguili
I have tried to reset the settings and marked Initialize with settings also in the Block menu. I am using 2D planar. So, I can not choose entities.
October 13, 2011, 00:35 |
KJ Lee
try using 3D blocking instead. I had a geometry similar to yours and using 3D blocking, never had a problem.
October 13, 2011, 03:29 |
AB
Rep Power: 21 |
If you blank the part "VORFN", it should be good.
October 13, 2011, 13:06 |
Guiliguili
No. I did not blank the "VORFN" part just to show that I am missing a vetical line on the right side of my domain and the blocking is not closed on the right and the left sides (See the third picture attached)
August 5, 2012, 17:07 |
Solved
Guiliguili
It was the tolerance which were too big. I reduced the tolerances in Menu -> Settings -> Model
[ICEM] Using Blocking with ICEM (infinite blocking lines appeared) | Touré | ANSYS Meshing & Geometry | 2 | August 5, 2012 17:27 |
[ICEM] ICEM surface trim and blocking projection | Felipe Mendes | ANSYS Meshing & Geometry | 3 | May 21, 2012 03:08 |
Ansys ICEM 12.0 Searching for tutorial information on complex 3d blocking | Raoul | ANSYS | 1 | October 18, 2010 06:08 |
surface flow lines in ICEM postprocessing | Dimitri | CFX | 0 | July 18, 2007 11:30 |
ICEM Blocking 2D and Fluent error | Dr. Flow Squad | FLUENT | 3 | March 5, 2007 02:27 |
