ICEM - strange linking problem
Old   September 19, 2011, 04:24
Default ICEM - strange linking problem
RodriguezFatz's Avatar
Philipp
RodriguezFatz will become famous soon enough
Dear all,
I have some strange linking problem in icem. (please see attached picture)
When I change the number of edge nodes in the left blocks (in direction of the red arrow), also the number of nodes in the right blocks changes to the same number. I don't find any linking between the two blocks, so how can I prevent icem from doing this?
Thanks for any help,
Philipp.
RodriguezFatz is offline   Reply With Quote
Old   September 20, 2011, 12:54
PSYMN's Avatar
Simon Pereira
PSYMN has a spectacular aura aboutPSYMN has a spectacular aura about
Check the index control to see what it thinks of the two "unrelated" edges, try splitting across that first block and see how it propagates, etc... Turn on the VORFN blocks to see if that reveals anything.
If that connection is behind the scenes in the VORFN blocks, you can break it pretty easily. Go to delete blocks, turn on the option for "permanently" and delete all the banked (VORFN) blocks. This will delete your VORFN region and re-create it without the hidden connections that you have currently.
Beware! This could mess with your index control since it starts a whole new index based on your visible blocking...
Please help guide development at ANSYS by filling in these surveys
Public ANSYS ICEM CFD Users Survey
This second one is more general (Gambit, TGrid and ANSYS Meshing users welcome)...
CFD Online Users Survey
PSYMN is offline   Reply With Quote
Old   September 21, 2011, 02:12
Philipp
Thank you very much, I will try that!!
Old   October 25, 2011, 03:25
camoesas is on a distinguished road
I had a similar problem, it worked for me.
Thanks PSYMN
OF - 2.0.0
camoesas is offline   Reply With Quote
ICEM keyboard problem in linux gravis ANSYS Meshing & Geometry 4 February 28, 2020 09:23
Problem in running ICEM grid in Openfoam Tarak OpenFOAM 6 September 9, 2011 17:51
[ICEM] ICEM meshing problem xyq102296 ANSYS Meshing & Geometry 6 October 28, 2010 10:09
Region Problem with ansys 12 icem mesh for cfx compizer CFX 0 May 5, 2010 03:02
ICEM hexa 2d car example problem icem student CFX 1 May 16, 2008 16:01
