[GAMBIT] Ask about how to set up geometry and mesh for moving mesh case
Like Tree1Likes
Old   December 20, 2011, 03:08
-mAx-'s Avatar
Maxime Perelli
-mAx- will become famous soon enough
yes enable the dynamic mesh, else you cannot access to dynamic mesh zone.
But don't change anything, since your mesh will not be updated (no layering, no smoothing and no remeshing)
In memory of my friend Hervé: CFD engineer & freerider
-mAx- is offline   Reply With Quote
Old   December 20, 2011, 03:13
noken
g-wagon is on a distinguished road
thanks boss, really appreciate it. btw come visit my country indonesia
g-wagon is offline   Reply With Quote
Old   December 21, 2011, 03:10
noken
hi max i have problem again..
i have two interface in my geometry in fluent i tried to connect them using coupled but the contour of velocity was so weird check this out
that is contour for initial solution..the wall is not rotating..but whay the fluid didnt pass the valve??
Old   December 21, 2011, 03:13
-mAx-'s Avatar
Maxime Perelli
yes you have problem at interfaces
Check if they are well defined.
I am in vacation untill January the 4th.
Old   December 21, 2011, 03:19
noken
but why??i think it had been defined well.. i have two surface not connected, i give that surface interface rotor and stator after that i use FLUENT to defined the interface type as coupled...
Old   December 21, 2011, 03:24
-mAx-'s Avatar
Maxime Perelli
no you need to define the edges as interface.
Between rotor and stator, only edges are common
Old   December 21, 2011, 03:26
noken
sorry i was wrong..i mean the edge of both stator and rotor
Old   December 21, 2011, 03:28
-mAx-'s Avatar
Maxime Perelli
no you mean one interface for the stator edges, and another interface for the rotor edges.
In Fluent select both interfaces to define the grid interfaces
Old   December 21, 2011, 03:30
noken
i've done that, and for the interface type i use coupled type
Old   January 2, 2012, 21:13
noken
hi max..me again hope you not bored with me
i'm facing a problem..yes again...
in my dynamic analysis using moving mesh, i'm facing the negative cell problem.. can you analysis what was wrong in my simulation, why did this comes up, here is what error like to be
Old   January 4, 2012, 01:47
-mAx-'s Avatar
Maxime Perelli
something is wrong since you are not suppose to change your mesh.
Check where are the negative cells
Old   February 3, 2012, 06:33
Efthymios Efthymiou
ftimis is on a distinguished road
Hi my friend, I am currently working on a similar project. I have to design a check valve. Is that working for you? Shall I follow the steps of your discussion??
ftimis is offline   Reply With Quote
Old   September 8, 2012, 11:26
Satish Gupta
Rahul123 is on a distinguished road
I am also plannin on using Sliding mesh to rotate a square Cylinder 2D....can ny1 help in defining interfaces.....I am not able to understand how we have two interfaces from d same circle...Do I have 2 make two circles nd define dem as interfaces
Rahul123 is offline   Reply With Quote
Old   September 10, 2012, 00:55
-mAx-'s Avatar
Maxime Perelli
imagine a surface with a hole (disk) > you are agree that in this surface you have a circle.
imagine now a disk not located on the surface mentionned earlier, but anywhere > you are agree that a circle (edge) is attached to this disk
You have then 2 circles.
Now move your disk in such way, that it will cover the hollow from first surface.
Finally you have defined a stator (first surface), and the rotor (disk) which are disconnected. And you also have 2 superposed interfaces (one belongs to stator surface and the other belongs to the rotort (disk)) Here the interfaces are the circles (edges)
I Hope I was clear
Marion likes this.
Old   September 10, 2012, 08:01
Satish Gupta
thanks max....How do I couple the two interfaces
1.coupled
2.periodic
or
3.periodic wall boundary.
I found these 3 options in fluent
Old   September 10, 2012, 08:03
-mAx-'s Avatar
Maxime Perelli
don't remember anymore, but coupled should be ok
Gambit problems Althea FLUENT 22 January 4, 2017 03:19
3D Hybrid Mesh Errors DarrenC ANSYS Meshing & Geometry 11 August 5, 2013 06:42
[Gmsh] 2D Mesh Generation Tutorial for GMSH aeroslacker OpenFOAM Meshing & Mesh Conversion 12 January 19, 2012 03:52
Icemcfd 11: Loss of mesh from surface mesh option? Joe CFX 2 March 26, 2007 18:10
