[GAMBIT] 2-d model pump help
Like Tree1Likes
  • 1 Post By Far
Old   December 13, 2011, 17:47
Default 2-d model pump help
tareqkh's Avatar
CFD
tareqkh is on a distinguished road
I am a Master's student at University of Tripoli. My thesis is about Study of radial thrus force around the impeller in Centrifugal pump and I am new to CFD. Can anyone please help me out with how to design and mesh an impeller in Gambit, or can you suggest some tutorials which will be useful in doing so? I just want to know the procedure of creating an 2d pump.
1-best way (simplist way of meshing)
2-I included the centrifugal pump model which is drown using CFturbo Software
Thanks.
tareqkh is offline   Reply With Quote
Old   December 14, 2011, 03:02
-mAx-'s Avatar
Maxime Perelli
-mAx- will become famous soon enough
Same question here: http://www.cfd-online.com/Forums/ans...s-meshing.html
In your case, from Impeller.dbs, define the edge (out-circle) as interface, and the fluid volume as rotor.
From volute.dbs, define the edge (in-circle) as interfaces, and the fluid as stator.
Now, export both mesh in fluent, and they should match together (meaning both interfaces are superposed).
You just need to define the grid interfaces, by selecting your 2 interfaces.
That's it
In memory of my friend Hervé: CFD engineer & freerider
-mAx- is offline   Reply With Quote
Old   December 14, 2011, 10:00
Default plz show me how
tareqkh's Avatar
CFD
I am so tired from this model
can u modify and attatch the modified model
plz help me
Old   December 23, 2011, 17:59
Far
Sijal
Far has a spectacular aura aboutFar has a spectacular aura about
Send a message via Skype™ to Far
here it is
meoiotu likes this.
Far is offline   Reply With Quote
multiphaseInterFoam for RAS turbulence model chiven OpenFOAM Bugs 8 December 6, 2017 02:08
2 stage axial turbine model convergence issues sherifkadry CFX 2 September 7, 2009 20:51
multi fluid mixture model issue rystokes CFX 3 August 9, 2009 19:13
LES and combustion model Margherita Cadorin CFX 0 October 29, 2008 05:24
Advanced Turbulence Modeling in Fluent, Realizable k-epsilon Model Jonas Larsson FLUENT 5 March 13, 2000 03:27
