[ICEM] Hex-Core disconected
Like Tree1Likes
  • 1 Post By PSYMN
Old   December 15, 2011, 12:18
Default Hex-Core disconected
Max
max3.2 is on a distinguished road
Hey Guys,
I'm trying to mesh a duct flow with tets, prisms and hexa core. Everytime I try to do so, the hexa-core seems to be disconnected from the outside prisms. Theres's just a free space in the cut plane and the hexa elements are way to big. Mesh checks confirms unconnected faces.
I can't find any way around it, anyone knows what could possibly be wrong?
Cheers
Max
max3.2 is offline   Reply With Quote
Old   December 15, 2011, 12:45
Max
little update: if i do the hex first, prism wont work but hex does. other way around its prisms but no hex
Old   December 19, 2011, 11:37
Default Recommend Change Mesh Type => 12 Tetra to 1 Hexa instead.
PSYMN's Avatar
Simon Pereira
PSYMN has a spectacular aura aboutPSYMN has a spectacular aura about
Hex core works by deleting the prisms, meshing the region with a cartesian fill, then deleting the hexas that intersect the surrounding elements and then filling the gap with a delaunay tetra fill (gives you pyramids where needed).
The size of the Cartesian mesh is set by the size on the volume part (this is one of the few times that size on a volume part is used). If your hexas are too large, you could reduce this size.
The delaunay fill can fail for several reasons including too much of a size jump between the hexas and the surrounding elements or due to hanging nodes on the external surface of the hexa core block.
Personally, I avoid use of hexa core. I do not find it to be robust.
Instead, I suggest you use Octree Tetra. Then run an editing step to change mesh type and convert 12 tetras to 1 hexa. This will give you what you are really looking for.
Note: Prism is insterted post tetra and can only move tetras out of the way. It must be run before either Hexa Core or Tet to Hex conversion...
MDB likes this.
Please help guide development at ANSYS by filling in these surveys
Public ANSYS ICEM CFD Users Survey
This second one is more general (Gambit, TGrid and ANSYS Meshing users welcome)...
CFD Online Users Survey
PSYMN is offline   Reply With Quote
Old   December 25, 2011, 14:42
Max
Hey,
Thank you that works fine now. Is the he a size only determined by the gets or is there a way to change them once they are created?
Old   January 3, 2012, 16:01
PSYMN's Avatar
Simon Pereira
When you are converting tet to hex, the size of the hexas is determined by the size of the tetras...
solving a conduction problem in FLUENT using UDF Avin2407 Fluent UDF and Scheme Programming 1 March 13, 2015 02:02
Superlinear speedup in OpenFOAM 13 msrinath80 OpenFOAM Running, Solving & CFD 18 March 3, 2015 05:36
[blockMesh] BlockMesh number internal faces and boundary ynos OpenFOAM Meshing & Mesh Conversion 6 December 13, 2011 05:36
[blockMesh] Blockmesh error - 2D scramjet ishaninair OpenFOAM Meshing & Mesh Conversion 7 March 18, 2011 00:14
CheckMeshbs errors ivanyao OpenFOAM Running, Solving & CFD 2 March 11, 2009 02:34
