[GAMBIT] Error message: Cannot link faces due to all loops of edges not being specified
Like Tree2Likes
  • 1 Post By swiftaircraft
  • 1 Post By Aerogirl
Old   January 30, 2012, 12:31
Unhappy Error message: Cannot link faces due to all loops of edges not being specified
PB
Aerogirl is on a distinguished road
Hi all ,
I am using GAMBIT software to model the flow between two gas turbine blades, I am trying to specify periodic/cyclic boundary conditions to the flow before and after the blades and keep getting the above error message whenever I try to hard link the faces. My procedure up until this point is as follows,
If the two opposite faces are assumed to be rectangular:
Mesh edges of one of the faces and hard link them, no error so far.
Mesh the faces of one side and attempt to hard link them using the edges and vertices required in the box, here is where the error message appears saying that I cannot link them.
I have tried a variety of different combinations of meshing and linking but cannot get further than trying to hard link the faces.
If anyone has any suggestions they would be greatly appreciated as I cant seem to find this error message or any solutions anywhere on Google.
Thanks
Aerogirl is offline   Reply With Quote
Old   January 31, 2012, 01:05
-mAx-'s Avatar
Maxime Perelli
Can you reproduce your issue on a simple cube by trying to hard-link opposite faces?
Old   January 31, 2012, 04:10
David Stanbridge
swiftaircraft is on a distinguished road
Do you have more than one edge making up each of the edges of the rectangular end faces? This error message is common in these situations.
jerseh hadi likes this.
David Stanbridge
Swift TG Solutions Limited
www.swifttgsolutions.com
swiftaircraft is offline   Reply With Quote
Old   January 31, 2012, 11:56
Far
Sijal
can you please attach the snap shot of gambit screen?
Old   February 19, 2012, 08:21
Smile Solution to problem
PB
Hi all, I have managed to sort the problem very simply, instead of selecting all vertices of the faces i want to link I just selected one on each face and this solved the problem! Thanks for all suggestions!
Mojtaba.a likes this.
cyclic boundary, error message, gambit 2.4.6, hard link, periodic boundary
[snappyHexMesh] SnappyHexMesh for internal Flow vishwa OpenFOAM Meshing & Mesh Conversion 24 June 27, 2016 08:54
motorBike tutorial doesn't work out-of-the-box Wolle OpenFOAM 23 April 21, 2010 08:19
[snappyHexMesh] external flow with snappyHexMesh chelvistero OpenFOAM Meshing & Mesh Conversion 11 January 15, 2010 19:43
Left-handed faces due to non-convex cells? Crystal FLUENT 3 July 31, 2009 07:41
non-planar faces due to the deformation of grid gonski Main CFD Forum 5 November 12, 2007 15:25
