[ANSYS Meshing] Meshing a fluid NOT as a surface body
Old   February 8, 2012, 12:15
Question Meshing a fluid NOT as a surface body
Sophie
Soph is on a distinguished road
I'm a beginner to Ansys, currently trying model an artery with blood flowing through it. Its a very basic 3D model and I've created the geometry; one fluid body (the blood) inside a solid body (the artery) its essentially a cylinder shape.
When i try to mesh it and put it into fluent the mesh on the fluid part dissapears because its a surface body, but i dont understand how to mesh it correctly so that the mesh stays for the fluid in fluent.
Can anyone help me please?
Thanks
Soph is offline   Reply With Quote
Old   February 8, 2012, 13:49
Far
Sijal
consider the artery as fluid body and mesh from inside (cylinder type) and do not model thickness of it (if any ). CFD software will take care of blood flow
Old   February 9, 2012, 11:29
PSYMN's Avatar
Simon Pereira
This should work no problem... People do it quite regularly, especially for conjugate heat transfer examples where you want to model fluid flow and heat transfer thru solids...
What are you using to mesh this?
I am guessing ANSYS Meshing. In that case you need to put each body into a Named Selection... When you get to Fluent, these volume named selections will apear as Zones. Then apply the correct properties to each zone and you will be set...
CFD Online Users Survey
3d modelling, fluid flow, mesh generation, surface body
[Gmsh] Problem with Gmsh nishant_hull OpenFOAM Meshing & Mesh Conversion 23 August 5, 2015 02:09
[Gmsh] boundaries with gmshToFoam‏ ouafa OpenFOAM Meshing & Mesh Conversion 7 May 21, 2010 12:43
surface to s. radiation in air above transp. fluid dace CFX 1 March 3, 2009 07:35
fluid structure interaction taru agrawal FLUENT 4 September 10, 2007 03:12
