[ANSYS Meshing] Can ANSYS ICEM CFD produce quadratic hexa?
Old   February 20, 2012, 02:45
Post Can ANSYS ICEM CFD produce quadratic hexa?
nalanrongruo
a79755172 is on a distinguished road
Hello,everyone.
Now I am using the ANSYS ICEM CFD to mesh geometry to get the high quality hexahedron. I use these hexahedra in the computational electromagnetics. even though I learn it for months, I still have some questions to ask.
1.Now I can only produce and export linear hexahedron, and I want to know can these hexahydra conform the geometry perfectly? For example, I want to mesh a ball, does the linear hexahedra conform to the ball's curved face perfectly? And, does ANSYS ICEM CFD has the ability to produce quadratic hexahedra and export the 27 nodes of these hexahedra?
2.Following the first question,when we use this software to judge the hexa's quality, what's the difference between determinant 2󫎾 and determinant 3󫢫. If the ICEM can only produce linear hexahedra, these two methods can get the same answer. So what's the use does the determinant 3󫢫 have? The procedure using 8 nodes to judge the hexa may simple and faster?
Thank you and I am waiting for your answer!
a79755172 is offline   Reply With Quote
Old   May 22, 2012, 09:29
Default Add Midside Nodes
PSYMN's Avatar
Simon Pereira
PSYMN has a spectacular aura aboutPSYMN has a spectacular aura about
Sorry I am so far behind on answering some of these questions...
ICEM Hexa now produces only linear Hexa... You are right about the 3X3X3 check, it seems kind of silly.
However, you can convert your linear hexas to quadratic hexa using Edit Mesh => Convert Mesh Type => Add Midside nodes.
These nodes can be auto-projected to the geometry.
Please help guide development at ANSYS by filling in these surveys
Public ANSYS ICEM CFD Users Survey
This second one is more general (Gambit, TGrid and ANSYS Meshing users welcome)...
CFD Online Users Survey
PSYMN is offline   Reply With Quote
Old   May 30, 2012, 01:58
Rikio
rikio is on a distinguished road
Send a message via Skype™ to rikio
There is an option under the shell meshing parameter, quadratic elements. Is it only useful for shell meshes?
Pls see another post of mine, http://www.cfd-online.com/Forums/ans...ents-used.html
rikio is offline   Reply With Quote
Old   May 31, 2012, 10:25
PSYMN's Avatar
Simon Pereira
Quadratic mesh is for FEA solvers, CFD solvers typically use Linear elements.
Old   May 24, 2015, 04:56
Default Adding Midside Nodes works
wangteng
tengwang is on a distinguished road
I obtain 9-node quad elements and 27-node elemnts through adding a midside node. Then the element information of 9-node element can be exported with all 9 nodes, while i can only get 20 nodes of 27-node element through '' export mesh" . so how can I export all 27 nodes of a cubic element in nastran format?
tengwang is offline   Reply With Quote
determinant, quadratic hexahedra
[ICEM] Ansys 13 ICEM CFD Tutorial (Latest) sharendr ANSYS Meshing & Geometry 12 March 7, 2012 08:56
Hybrid mesh in 2D in ANSYS ICEM CFD Alex CFX 6 March 5, 2011 16:32
ANSYS ICEM CFD Ver11.0 Max CFX 4 October 22, 2008 16:35
Hexa ICEM CFD Amit CFX 3 July 28, 2008 18:48
Hexa smoothing (ICEM CFD 10.0) CFDworker CFX 3 November 2, 2005 10:23
