[GAMBIT] DI diesel engine moving mesh using Star cd
Old   February 23, 2012, 09:19
Default DI diesel engine moving mesh using Star cd
Mrinal K R
MrinalKR is on a distinguished road
I'm a fresher in CFD. I created 2D moving mesh using Star cd-3.26. Now i want to make it in 3D. The piston is bowl type. i created the model using solid works 2010 and plan to do meshing in Gambit and analysis in Star CD. Anyone can help how to start from the geomtryitself. please also tell how to mesh an engine in gambit.
MrinalKR is offline   Reply With Quote
Old   February 27, 2012, 01:18
-mAx-'s Avatar
Maxime Perelli
-mAx- will become famous soon enough
try first to import your geometry in gambit (step file should be ok)
In memory of my friend Hervé: CFD engineer & freerider
-mAx- is offline   Reply With Quote
Old   February 27, 2012, 01:33
Mrinal K R
Thank you for your reply sir. I created one geometry with cylinder(stroke),valve seat,runner and valve in solid works. For importing to gambit and star cd,what type of geometry is required?wheater its full stroke length or clearence volume? In gambit how can i mesh. I did one gambit tutorial related to volume split. I guess that volume method will be usefull for my model also.
Old   February 27, 2012, 01:42
-mAx-'s Avatar
Maxime Perelli
import your geometry in gambit, mesh it, apply boundary conditions and export your mesh for your solver.
But before, I would check that at least one mesh export possibility in gambit could match your mesh import in star cd.
Except generic solver, I don't see any other
http://my.fit.edu/itresources/manual...tm#menu_solver
Old   February 27, 2012, 02:32
Mrinal K R
Thank you sir. I dont know how to mesh an ic engine in gambit to get the moving mesh and valve motion.
Old   February 27, 2012, 02:39
Mrinal K R
If you have any file or tutorial(3D analysis in ic engine),can u please post or send to my mail mrinal1729@gmail.com.
Old   February 27, 2012, 06:09
-mAx-'s Avatar
Maxime Perelli
not IC tutorial, but moving mesh
http://my.fit.edu/itresources/manual...tg/node207.htm
Old   February 27, 2012, 06:27
Mrinal K R
thank you for your reply sir. can u tell how to mesh engine in gambit?
Old   February 27, 2012, 09:28
-mAx-'s Avatar
Maxime Perelli
there are no guide for meshing an engine or whatever.
I depends on the geometry.
Import your geometry, extract the fluid domain.
From here you can mesh the domain on the fly.
But for sure you will have to split it many times, for better quality mesh
Old   February 27, 2012, 11:08
Mrinal K R
Thank you sir for your valuable information. Can u tell how to mesh the valve region? With my limited knowldege i came to know that layer type meshing is used.i dont know much about that.if you dont mind can you tell how to do layering in valve region?
Old   February 28, 2012, 01:13
-mAx-'s Avatar
Maxime Perelli
ok quick...
let say you have a rectangle, and the upper edge will move (up or down)
*define the upper edge as rigid body and set its motion
you also have to specify the cell height parameter from which the solver will collapse or create the cell layers
*define the lower edge as stationnary
Of course your rectangle is meshed with quad.
Don't expect to get your model working at first attempt. But in this way you will understand how it work. Always testing with very simple example...
Old   February 28, 2012, 01:37
Mrinal K R
Thank you sir for your help. I didnt get any help from anybody.i used to do the tutorial and read the user guide.i'l try to do this.
Old   April 18, 2016, 03:19
Pradeep
pradeep6890 is on a distinguished road
You could try meshing in es-ice which is quite easy for engine simulation
pradeep6890 is offline   Reply With Quote
Gambit problems Althea FLUENT 22 January 4, 2017 03:19
[Other] StarToFoam error Kart OpenFOAM Meshing & Mesh Conversion 1 February 4, 2010 04:38
How to control Minximum mesh space? hung FLUENT 7 April 18, 2005 09:38
Couples usage in engine moving mesh Alfred Herman Siemens 0 May 15, 2003 04:12
