[ICEM] Structured Hexa Mesh on Wing
Like Tree12Likes
Old   August 5, 2013, 10:22
Far
Sijal
Far has a spectacular aura aboutFar has a spectacular aura about
Send a message via Skype™ to Far
I took a look on your case. It is not possible to get good hexa with such angle.
Far is offline   Reply With Quote
Old   August 9, 2013, 11:10
crostolo is on a distinguished road
Hi Far,
I scratch my head on for a while on that geometry. Finally I was able to reach a quality > 0.25 - 0.3
On the tail on the wing section I recreate your blocking strategy (two blocks tangent to for a diamond) and than I select each faces of them and under
edit block --> convert block type --> I chose type Y block and in the image attached you can see how it looks like
If anyone has other advices how to improve the quality, I attach the .blk and .tin files if you want to see (I reckon my blocking is a bit ..messy )
crostolo is offline   Reply With Quote
Old   December 22, 2013, 05:24
Question
  #63
Anna Tian's Avatar
Meimei Wang
Anna Tian is on a distinguished road
Originally Posted by Far View Post
Method 2
http://www.4shared.com/rar/qXCmda1T/file.html
In this method, O block around wing is created first (blocks collapsed in previous step at trailing edge), then tip block is split into two parts one for leading edge and one for trailing. For trailing edge block with 3 edges, Y-block is inserted. For the leading edge block, O-block is applied. See attachments and Figs.
Now working on method 3, that is not to use the collapse block command and simply creating O-block around air foil assuming trailing edge is also round.
I also tried to generate the mesh in this way. But the problem is the trailing edge angle for my airfoil is lower than 18 degrees (I model the airfoil NACA 2412). So even though you use the Y-block, you still have the smallest grids angle lower than 18 degree. Any thought about this trailing edge angle constraint? How to solve this problem without introducing GGI?
Best regards,
Meimei
Anna Tian is offline   Reply With Quote
Old   December 22, 2013, 06:01
Far
Sijal
Collapse the block in trailing edge. And in the trailing edge block converte mesh to free type.
Old   February 3, 2014, 10:59
Question
  #65
Anna Tian's Avatar
Meimei Wang
What do you mean by free type? Unstructured grids?
Best regards,
Meimei
Old   February 3, 2014, 11:03
Far
Sijal
yes. It will improve quality in the regions where hexa mesh wont fit...
Old   February 3, 2014, 11:08
Anna Tian's Avatar
Meimei Wang
I tested GGI for different AoA. GGI works well for the wing tip interface (at least for my case). So I have a feeling that actually we don't need those complex grids generation strategy at all.
Another way to solve this problem is to round the very tiny small trailing edge tip. It is widely known in the airfoil aerodynamics that rounding of trailing edge tip slightly won't change its performance and the flow. And also there is manufacturing tolerance. So it can't be perfectly sharp naturally.
Best regards,
Meimei
Old   February 3, 2014, 11:16
Far
Sijal
Yes you are correct.
GGI works fine with new software technology
Sharp angles are possible to manufacture in reality...
Old   February 4, 2014, 04:44
Question
  #69
Anna Tian's Avatar
Meimei Wang
Yes. Sharp angles can be manufactured. But the radius of the sharp trailing edge will still naturally exist (like 0.01 mm or even smaller). We can just use that tiny radius in CFD. Then we won't have to model the sharp angles and use Y block anymore even though our grids at the trailing edge might have to be very small to capture the radius. But we won't run into any grids quality problem any more. This also reduces the grids generation complexity.
Best regards,
Meimei
Old   May 31, 2016, 04:02
Default winglet mesh problem
  #70
mohamadreza
mrh111 is on a distinguished road
hi
I tried to generate mesh around wing with winglet in ICEM but after generating mesh the quality of mesh is very low and I give some error in fluent.
3 pictures are attached.
Hope any of you can give me an advice for a better blocking strategy or any other suggestion is welcomed.
http://uupload.ir/files/92i4_1.jpg
http://uupload.ir/files/r4bh_2.jpg
http://uupload.ir/files/nd2n_3.jpg
mrh111 is offline   Reply With Quote
Old   May 31, 2016, 18:14
B.H.
niablis is on a distinguished road
Hi mrh111, there doesn't seem to be any attached pictures or files.
niablis is offline   Reply With Quote
Old   June 3, 2016, 04:14
mohamadreza
is that fixed?
Old   June 3, 2016, 16:19
B.H.
Yes it did!
Ok so I can't tell much from the pictures; nothing is really standing out that would cause errors. It looks like you used an O-grid for the wing, but how did you transition from the wing to the winglet using the O-grid? If I can to guess, it would be that your problem is occurring at the intersection of the winglet and the wing. It is possible to create an O-grid in an "L" shape, which might work better for you.
If you want, you can post your file and I'll look at it over the weekend.
Old   June 5, 2016, 05:10
mohamadreza
Originally Posted by niablis View Post
Yes it did!
it's very kind of you.i will be really grateful.
http://up.persianscript.ir/uploads2/...-winglet-6.rar
actually i guess i fixed the "L" shape problem. but the quality of mesh is still low
and i get some error in FLUENT.
http://up.persianscript.ir/uploads2/...-winglet-7.rar
http://up.persianscript.ir/uploadsmedia/75f0-44444.jpg
http://up.persianscript.ir/uploadsmedia/75f0-55555.jpg
Old   June 6, 2016, 12:34
B.H.
Hi mrh111,
I took a look at your file. Great job with using the O-grid on the winglet. I did find two problems, however. First, there is an association problem with one of the blocks on the bottom side of the wing near the winglet. See the first attached image. This is very likely causing some or all of your Fluent errors. Secondly, as can be seen in the second attached image, the cells right of the wing have quite a large aspect ratio. I would consider refining them for best performance.
In case you didn't already know, you can find "Scan Planes" in the drop down menu when you right click on the "Pre-Mesh" item under "Blocking". It is very, very helpful when working with structured meshes and blocking.
Hope this helps, and good luck!
-Ben
Old   June 6, 2016, 13:26
Far
Sijal
I dont see any curves in geometry.
Old   July 4, 2016, 16:55
Far
Sijal
to complete the thread, please see this new part with new method to mesh same geometry.
https://www.youtube.com/watch?v=UO8RJWsIV40
Old   July 12, 2017, 22:52
dario
dariodario32 is on a distinguished road
Hallo,
I tried to follow this tutorial, but when I try to compute the mesh I have the following error:
Running hexa-dominant mesher...
{expecting 2 shells on edge 18 14 found 4
error orienting normals, perhaps there is more than one region
error in output_boundaries
Hex Dominant meshing failed
Could you please check my files?
files --> https://drive.google.com/open?id=0B0...3RFdmV5TzJ5Wk0
Thanks
SOLVED
dariodario32 is offline   Reply With Quote
blocking strategy, icem cfd airfoil geometry
LinkBacks (?)
LinkBack to this Thread: https://www.cfd-online.com/Forums/ansys-meshing/98390-structured-hexa-mesh-wing.html
Posted By For Type Date
ICEM Hexa meshing tutorial - Wing with sharp trailing edge This thread Refback October 18, 2013 03:30
[ANSYS Meshing] Workbench 13: Structured Hexa Meshes rooftop ANSYS Meshing & Geometry 19 March 31, 2016 02:33
Exporting structured mesh from ICEMCFD to Fluent? jeevan kumar FLUENT 1 January 23, 2012 11:21
[snappyHexMesh] snappyHexMesh won't work - zeros everywhere! sc298 OpenFOAM Meshing & Mesh Conversion 2 March 27, 2011 21:11
Highly skewed and inverted volumes in wing mesh makaero FLUENT 0 December 8, 2009 19:32
Structured Grid Definition craig shores Main CFD Forum 3 March 21, 2001 14:48
