[ANSYS Meshing] Can someone help with that Mesh??? |
January 11, 2012, 12:21 |
Ofir Laor
Rep Power: 14 |
Unsuccessfully, I’m trying to make FLUENT to accept my MESH file (in ANSYS WorkBench), and I’m quite stuck with it… I’m trying to simulate the 2D flow over the shape that I attached to this thread. Somehow, no matter which shape of domain I’m using, when trying to do the SETUP, and updating the MESH, I get this message over and over again- “The mesh file exporter failed during translation…“ I tried splitting the domain into different areas and Map it, I tried Sizing controls… But still, nothing… If anyone have a good idea - I’ll be grateful, Thanks |
January 12, 2012, 06:06 |
Ofir Laor
Rep Power: 14 |
Well, Basicly I’m meshing in the Mesh software of ANSYS 13, and then open it with FLUENT directly from WorkBench.
However, I can export the MESH file as msh, meshdat and also poly,cgns,prj and tgf. |
January 12, 2012, 07:54 |
Ofir Laor
Rep Power: 14 |
Yea, it is 2D on X-Y plane
January 12, 2012, 08:21 |
Relevant snapshots
Ofir Laor
Rep Power: 14 |
OK, so here are two snapshots, which I hope can be relevant...
(Even though I couldn't find any useful information from this... ) The first is from WorkBench, and the second is from the mesh program of one of the attempts |
February 14, 2012, 09:07 |
N7student
Rep Power: 14 |
Hello OfirLaor and Far
I am sorry to hijack this topic, but I have exactly the same problem with ANSYS Workbench 13.0 and whatever the simplest geometry and mesh I try to make, I have the same error message : "The mesh file exporter failed during translation..." Actually, I want to mesh a simple 2D square... The difference with OfirLaor's case is that I cannot export my mesh in ASCII MSH file (I obtain the same error message); I can export in binary formats however. Do you have any solution or advice for this problem? What is wrong with this? Thank you a lot for your help |
February 14, 2012, 16:04 |
#9 |
Ofir Laor
Rep Power: 14 |
Hi Neraste,
Unfortunately I can't help... Never find any solution to my problem as well.... Good Luck |
February 14, 2012, 16:24 |
#10 |
N7student
Rep Power: 14 |
So, what did you do? Did you use another mesher software?
February 14, 2012, 17:22 |
#11 |
Ofir Laor
Rep Power: 14 |
Well, this specific problem was the first out of 370 models I tested, in order to get some results, which I can analyse and compare between... So actualy, I didn't need a high resolution of accuracy. Therefore I solved the models with SolidWorks Flow simulation. However, if you're looking for a very accurate solution, I reccomend you to stay with Ansys... Please let me know if you find somthing... thanks
February 15, 2012, 05:36 |
#12 |
N7student
Rep Power: 14 |
The fact is I build meshes with Workbench long ago (one year...). But now, I am completelly unable to create any new one, even the simpliest square. That is very confusing...
If I have any trick, I will tell you. |
February 17, 2012, 05:07 |
#13 |
N7student
Rep Power: 14 |
Well, I have some news for you OfirLaor !
According to my school IT supervisor, version 13.1p1 of WorkBench isn't supported by Ubuntu yet, but it is OK under RHE 5 or SLES 10. Since I am working under Ubuntu, this should be the reason of the error message. Version 14 (and 13.0) should be (is) OK with Ubuntu. I will have a try with it as soon as my IT supervisor installs it. Hope it helps. |
February 17, 2012, 06:52 |
#14 |
JSM
Rep Power: 20 |
For Fluent 2D analysis through workbench, we need to change the simulation type to "2D" before opening DM & Ansys mesher in workbench schematic. This will be available in properties panel. To get the properties, right click the fluent flow and select properties Otherwise, Fluent will not accept the mesh. This might be the reason.
With regards, JSM |
February 17, 2012, 07:25 |
#15 |
N7student
Rep Power: 14 |
Well, jsm, actually I have already set this parameter on 2D.
I add I have tried a 3D cube and the result was exactly the same. The OS incompatibility is reported on ANSYS' technical website (I don't have the source). |
February 17, 2012, 17:12 |
#16 |
vlg
Rep Power: 17 |
Yes, version 13.0 works quite good on Ubuntu Linux.
February 20, 2012, 10:52 |
#17 |
N7student
Rep Power: 14 |
I have additionnaly some news for you! WorkBench on Linux needs a default Bash Shell (executables refers to /bin/bash). You have to set it up if your default shell is Sh or Tcsh (like in my school).
February 20, 2012, 15:00 |
#18 |
selcuk
this could be about cad file format. save as parasolid format may help you
April 9, 2012, 13:09 |
#19 |
Ofir Laor
Rep Power: 14 |
Hi Nerasta,
I got good news! Apparently, my problem was easy… I used Workbench and there I had “Mesh” system (box) which I have created the geometry and mesh, and I linked the mesh to other “Fluent” system to the setup. So that was somehow wrong to do… I did the same with one system of “FluidFlow (Fluent)”, and then I had no Error…. Hope this might help, Have a nice day! |
[ICEM] surface mesh merging problem | everest | ANSYS Meshing & Geometry | 44 | April 14, 2016 06:41 |
[ICEM] Problem making structural mesh on a surface | froztbear | ANSYS Meshing & Geometry | 1 | November 10, 2011 08:52 |
[snappyHexMesh] snappyHexMesh won't work - zeros everywhere! | sc298 | OpenFOAM Meshing & Mesh Conversion | 2 | March 27, 2011 21:11 |
Meshing aifoil in ICEM | student123a | ANSYS Meshing & Geometry | 13 | December 8, 2010 10:40 |
2d irregular grid | Remy | Main CFD Forum | 1 | December 22, 2008 04:49 |
