Using the same function for a number of locations in CFD Post |
April 30, 2012, 16:14 |
Scott
Rep Power: 14 |
Good Day everyone,
Just a simple query, does anyone have a trick for pointing an expression or function at bunch of different surfaces? I want to calculate heat flux from several contacting surfaces for a bunch of different components throughout my model. All I can find is methods to calculate one surface at a time, but I'd like to find a quicker method as I need to do this for many cases. Thanks in advance! |
May 9, 2012, 05:01 |
engin leblebici
Rep Power: 15 |
Dear Scott,
If I understood your problem correctly, you could write a UDF to obtain the heat transfer from a boundary of your problem and hook it to all the boundaries you want the heat transfer to be calculated. Just don't forget to change or include the coefficents according to the species of your boundaries. As far as I remember DEFINE _UDS_FLUX macro should solve your problem. Just tinker with it sometime. Regards |
May 9, 2012, 05:26 |
DB
Rep Power: 15 |
Hi Steady State,
If you are using CFX post, multiple surfaces can be selected simulatneously from the list.
-D.B |
[Other] mesh airfoil NACA0012 | anand_30 | OpenFOAM Meshing & Mesh Conversion | 13 | March 7, 2022 17:22 |
User CEL Function and CFD Post | chastain | CFX | 4 | September 24, 2013 13:58 |
[snappyHexMesh] external flow with snappyHexMesh | chelvistero | OpenFOAM Meshing & Mesh Conversion | 11 | January 15, 2010 19:43 |
[Commercial meshers] Trimmed cell and embedded refinement mesh conversion issues | michele | OpenFOAM Meshing & Mesh Conversion | 2 | July 15, 2005 04:15 |
