April 26, 2012, 07:36 |
Wind pressure on Roof
Sonam
Rep Power: 14 |
Hello
I am planning to use the ANSYS CFD for my thesis. But I am first time in CFD field. Please suggest me which software will be good to analysis the wind pressure on roof. Your suggestion and comments are welcome. |
April 26, 2012, 11:32 |
Ali
Rep Power: 16 |
Explain exactly what you want to do? Your final objective (results required)? Geometry ? etc..
Best Regards Ali |
April 26, 2012, 11:50 |
Sonam
Rep Power: 14 |
hi, thank you for the reply. Since, I am planning to analysis the wind pressure on different roof shape. Since, I dont have much idea about CFD model. What will be your suggestion in modelling the roof in CFD. Hear from you.
April 27, 2012, 02:10 |
#4 | |
Lucky
Rep Power: 66 |
My personal favorite is Fluent as it's very powerful. But CFX isn't too far behind in terms of capability. I think CFX wins the popularity contest. Some things to think about: is the simulation a steady-state type problem or transient/unsteady? incompressible / compressible is the flow laminar / turbulent for turbulent flows, it helps tremendously to know beforehand what others have used |
April 27, 2012, 02:55 |
#5 | |
Sonam
Rep Power: 14 |
May 7, 2012, 23:24 |
Suggest me one ANSYS software
Sonam
Rep Power: 14 |
I am planning to use one ANSYS software for my research on the Windstorm damage on the Traditional Roof. The height of building is around 15m. I would like to analysis with following condition 1. With parapate wall in the attic(close air passage) 2. Porous attic(the clear height between roof floor and eve of roof is around 1.5m open area) 3. Partially porous(i.e small wall and also timber plank use to close the open between the eve of roof and roof floor level) Please suggest me which ANSYS tool will be useful as per my condition. regards |
May 16, 2012, 08:13 |
Sonam
Rep Power: 14 |
thank you for the suggestion..........
Pressure Inlet VS velocity Inlet difference | Mohsin | FLUENT | 9 | January 4, 2021 10:34 |
How to read pressure at discrete points | paka | OpenFOAM | 16 | April 28, 2020 07:26 |
Pressure Drop/Porous Media within Shrouded Wind Turbine Simulation | joshdsouza | FLUENT | 0 | March 3, 2010 18:02 |
Pressure enigma. | Sara | Main CFD Forum | 22 | July 30, 2009 04:46 |
Hydrostatic pressure in 2-phase flow modeling (long) | DS & HB | Main CFD Forum | 0 | January 8, 2000 15:00 |
