Inappropriate zone type, inability to change to interoir & skipping of zones
Old   August 23, 2012, 09:23
Thumbs up Inappropriate zone type, inability to change to interoir & skipping of zones
Taiwo
Taiwo_Oni is on a distinguished road
Hi all,
Please, assist me to fix these probems:
Problem 1
I imported a mesh from Gambit into Fluent. The pictorial representation of the grid is attached. The cut1 & cut2 are the two holes that pass through the thickness of the strip. The strip is then inserted into the tube.
The following message appeared on the console:
Warning: Inappropriate zone type (interior) for one-sided face zone 5.
Changing to wall.
Error: Cannot change cutflow1 to interior because
there is only one adjacent cell thread.
Error Object: #f
cutflow1
Error: Cannot change cutflow2 to interior because
Error Object: #f
cutflow2
Problem 2
I imported a mesh from Gambit into Fluent. The pictorial representation of the grid is attached. (the same grid as in Problem 1). The cut1 & cut2 are the two holes that pass through the thickness of the strip. The strip is then inserted into the tube.
Removing 1157 unreferenced faces, zone 5.
Removing 1143 unreferenced faces, zone 6.
Warning: Number of nodes read (349210) does not match number referenced (346734).
Resetting counter to match the number referenced.
Skipping zone cut1 (not referenced by grid).
Skipping zone cut2 (not referenced by grid).
Thanks very much.
Taiwo_Oni is offline   Reply With Quote
cell, interior, node, thread, zone
transsonic nozzle with rhoSimpleFoam Unseen OpenFOAM Running, Solving & CFD 8 July 1, 2022 06:54
[Commercial meshers] Fluent3DMeshToFoam simvun OpenFOAM Meshing & Mesh Conversion 50 January 19, 2020 15:33
boundary conditions for simpleFoam calculation foam_noob OpenFOAM Running, Solving & CFD 8 July 1, 2015 08:07
[blockMesh] StitchMesh on two patches anita OpenFOAM Meshing & Mesh Conversion 31 April 4, 2013 11:51
Problem in running ICEM grid in Openfoam Tarak OpenFOAM 6 September 9, 2011 17:51
