CFD-Post not showing any results
Like Tree1Likes
  • 1 Post By ziggo
Old   May 13, 2013, 22:08
Default CFD-Post not showing any results
Bart A.
ziggo is on a distinguished road
I have done a transient 2D analysis of a flat plate in normal flow. I have 400 .cas files, one file for each timestep.
I managed to load these results in CFD-Post, but when I try to plot a contour plot, vector, anything at all CFD-Post does not plot anything. The progress bar indicates that something is happening, but I see no results.
For the contour for example I've tried all "Location" (interior, wall, symmetry 1, symmetry 2, etc...) but nothing worked. The things I tried are based on the tutorial given [here]
I have the feeling that I miss a simple setting, could someone help me a bit further please?
ziggo is offline   Reply With Quote
Old   May 20, 2013, 06:45
Bart A.
I've figured it out. There's some sort of bug with CFD post where on some machines it will not draw the plot to screen, but when you save the image as a .png the plot is there.
davidheinisch likes this.
Old   May 21, 2013, 02:03
Default not find opaque view
uk
ardismo is on a distinguished road
Hi;
Im trying to set up a view like
http://www.youtube.com/watch?v=z4jHIAfHG6Y
But i could not do it. So i cant create an animation file like this. I tried iso-surface, contour , isovolume but i could not achieve it.
Thank you.
ardismo is offline   Reply With Quote
Old   May 21, 2013, 03:05
Bart A.
But did you manage to run a simulation simulating this? Do you have cdat files?
If so, have you tried a volume rendering of your water? It's found under `Locations`
Old   May 21, 2013, 03:16
uk
i think its not volume randering . if you look at, it is not formed by a number of stages,it is continuous. It is a cfx run i have all trn files.Do you have another solution ?
Old   May 21, 2013, 03:24
Bart A.
Not sure what you mean by, "it is continuous". Every animation is formed by frames which represent a number of stages. If you play these number of stages sequentially you will get an animation. Here are the basics for making an animation in CFD-Post, I hope it's useful for you. If you have other questions, please make it concrete and describe your situation as full as possible.
Old   May 21, 2013, 03:50
uk
Main problem is to see free surface exactly. Volume randering is formed by different number of contours.not contuninuous means that. If you any two phase solution data could you you try these methods and try to catch view that i give by link( one picture is enaugh, no need animation) .
Old   May 21, 2013, 04:08
Bart A.
I unfortunately do not have two phase solution data and have never worked with it. Try posting your question in the ANSYS forum. Make it as concrete as possible asking exactly what you want to know. Good luck.
Old   May 28, 2013, 10:56
diamondx's Avatar
Ghazlani M. Ali
diamondx will become famous soon enough
do you get this error: http://www.cfd-online.com/Forums/flu...-cfd-post.html
Regards,
New to ICEM CFD, try this document --> https://goo.gl/KAOIwm
Ali
diamondx is offline   Reply With Quote
Old   May 28, 2013, 10:59
Bart A.
No, no error message. But as I state in my second image this must be some kind of incompatibility between CFD-Post and the machine I'm running on. The image is there when I export it as .png.
ansys 13, cfd-post
Guide: Getting Started with the CFD Online Discussion Forums pete Site Help, Feedback & Discussions 8 July 29, 2016 05:00
Future CFD Research Jas Main CFD Forum 10 March 30, 2013 12:26
Question Regarding CFD Post results sojourner FLUENT 0 February 4, 2013 10:46
CFD vs Experimetal Results for Aerofoil aceofharts414 Main CFD Forum 0 April 22, 2009 07:14
Impact of Humidity on CFD Results Jerry Main CFD Forum 2 January 26, 2004 14:39
