Home > Forums > Software User Forums > ANSYS
Parasolid to Ansys WB - Defeatured geometry
Old   June 27, 2013, 12:26
Default Parasolid to Ansys WB - Defeatured geometry
Danito is on a distinguished road
Hi!
I was given a parasolid file of an assembly consisting of a solid body and four surface bodies. I imported it into Ansys WB. However, the thicknesses of the surface bodies have not been preserved. Ansys shows zero and requires an imput.
I tried to make an "educated guess" about the missing thicknesses and changed the defeaturing tolerance, but it did not help.
I tried to run the Contact Tool to obtain initial contact information, but non is generated. The automatic contacts are recognized properly though.
I cannot even generate a mesh. Error message: The mesher did not generate any nodes. All geometry may have been defeatured away.
Has anyone else come across the same problem?
Any ideas and suggestions how to fix this problem?
Thank you!
Danito is offline   Reply With Quote
Making wing geometry in Ansys 12.1 akash_morar ANSYS Meshing & Geometry 3 September 26, 2013 14:46
Geometry for pipe in Ansys Workbench riteshpalkar ANSYS Meshing & Geometry 0 June 24, 2013 04:52
Ansys Design Modeler complex geometry natantyt ANSYS Meshing & Geometry 1 October 17, 2011 08:57
Need help on geometry forming for room in ANSYS binghong ANSYS 0 November 4, 2010 06:03
Problem importing GAMBIT mesh to Ansys geometry David G. CFX 0 June 19, 2005 06:01
