November 1, 2013, 03:33 |
A problem about Fluent reference value
Yao Lu
Rep Power: 12 |
I'm solving a 3D flow around a circular cylinder case with air dielectric and LES model. However, the drag coefficient of cylinder wall doesn't match the value announced on papers.
Reference value is set as follows: length = diameter of cylinder area = diameter * height of cylinder; for 2D case, diameter of cylinder velocity = velocity of inlet viscosity = viscosity of air Are they right or wrong? Thanks in advance. |
November 1, 2013, 05:51 |
Alex
Rep Power: 47 |
There is not necessarily a right or wrong when it comes to reference values.
The ones you have are an obvious choice, but someone else might find the surface of the cylinder more appropriate than the projected surface for the area reference value... Since you are comparing your results to those in some papers, you simply take the same reference values as reported in these papers. If they give coefficient values without stating the reference values used to obtain them, I would start searching for other sources to compare your results. |
Simulation of a single bubble with a VOF-method | Suzzn | CFX | 21 | January 29, 2018 00:58 |
It would be wonderful if a tool for FoamToTecplot is available | luckyluke | OpenFOAM Post-Processing | 165 | November 27, 2012 06:54 |
Installing OpenFOAM-1.5-dev on a cluster | ZKM | OpenFOAM Installation | 4 | December 25, 2010 15:59 |
Compiling new Solver with wmake | lin123 | OpenFOAM | 3 | April 13, 2010 14:18 |
Windows Installation BugsComments on Petrbs patch | brooksmoses | OpenFOAM Installation | 48 | April 16, 2006 00:20 |
