How to set two phase flow
Old   May 4, 2015, 21:02
Default How to set two phase flow
yas6ser is on a distinguished road
Hi all
I'm using ansys 15
I'm using fluent
Two phase flow water and air
I set phase 1 water
Phase 2 air
But there is no option to set deferent velocity for each phase
Just velocity for the mixture fluid
Can any one help me
How to set deferent velocity for each phase
yas6ser is offline   Reply With Quote
Old   May 5, 2015, 09:36
Henry Arrigo
Henry Arrigo is on a distinguished road
I think you should determine which module you are going to use beforehand, e.g FLUENT/CFX. Then you would be able to find relevant tutorial in their documentation.
Henry Arrigo is offline   Reply With Quote
Old   May 12, 2015, 19:48
Thanx a lot for your replay
I'm using fluent
Issues on the simulation of high-speed compressible flow within turbomachinery dowlee OpenFOAM Running, Solving & CFD 11 August 6, 2021 06:40
About Some Concepts:Laminar flow, turbulent flow, steady flow and time-dependent flow Jing Main CFD Forum 8 October 5, 2018 17:02
Three Phase flow into a reservoir... akjha Main CFD Forum 0 December 15, 2014 07:01
Divergence in Two phase flow in impeller for Cavitation joshghoun Fluent Multiphase 2 November 5, 2014 09:33
How to set phase dependent turbulence models? J.Yang CFX 2 August 29, 2002 15:39
