ansys command * get help
Old   May 15, 2016, 08:18
Default ansys command * get help
davide ilmigliore
aiace is on a distinguished road
Hi, I created a template using a heatsink ansys APDL , and I calculated the thermal solutions in the event that this heat sink to dissipate heat by convection and conduction and then I calculated the mechanical solution . Then I wanted to ask how I can extract such as the von mises tension through function * get and write this value in a txt file. I also want to extract the value of the temperature and the higher the value of the highest voltage , and write it on a txt file. I have tried using the following code , but it tells me error enough date format ... __________________________________________________ ______ * GET , x , PLNSOL , 0 , max , , , * Cfopen , ' s ' , ' txt ' ,, append * Vwrite , x finish
__________________________________________________ ________
The code around the program without the get function is:
finish
/clear
/filname,dissipatore
/prep7
*SET,b,0.0045
*SET,h,0.05
*SET,ba,0.002
*SET,h,0.070
*SET,ba,0.0005
*SET,b,0.001
*SET,adduzione,45
*SET,temp,40
ET,2,PLANE55
MPTEMP,,,,,,,,
MPTEMP,1,0
MPDATA,KXX,1,,365
MPTEMP,,,,,,,,
MPTEMP,1,0
MPDATA,KXX,2,,180
RECTNG,0,0.004,0,b,
RECTNG,0.004,0.008+b-ba,0,b,
RECTNG,0.008+b-ba,h,0,ba,
cyl4,0.008+b-ba,b,b-ba,,,
asba,2,4
aadd,5,3
aglue,1,2
asel,s,area,,1
aatt,1,,1,0,
allsel,all
asel,s,area,,3
aatt,2,,1,0,
allsel,all
aesize,all,ba/5,
!Bisogna assegnare gli elementi alle aree: andare su meshing-->mesh attributes-->picked areas--> seleziono l'area 1
!e gli assegno l'elemento 2 plane55 e faccio lo stesso con l'area 2
amesh,all
SFL,2,HFLUX,(60*2)/(0.05*0.05),
SFL,7,CONV,adduzione, ,temp,
SFL,10,CONV,adduzione, ,temp,
SFL,11,CONV,adduzione, ,temp,
SFL,12,CONV,adduzione, ,temp,
finish
/sol
solve
finish
/post1
plnsol,temp,,0
!fine parte termica
!inizio parte meccanica
finish
/prep7
lsclear,all
etchg,tts
mptemp,,,,,,,,
mptemp,1,0
uimp,1,reft,,,20
mpdata,alpx,1,,12.5e-6
mptemp,,,,,,,,
mptemp,1,0
uimp,2,reft,,,20
mpdata,alpx,2,,24.2e-6
mptemp,,,,,,,,
mptemp,1,0
mpdata,ex,1,,110e9
mpdata,prxy,1,,0.35
mptemp,1,0
mpdata,ex,2,,68.9e9
mpdata,prxy,2,,0.33
tb,biso,2,1,2,
tbtemp,0
tbdata,,60e6,2200e6,,,,
tb,biso,1,1,2,
tbtemp,0
tbdata,,60e6,1380e6,,,,
dl,4, ,ux,0
dl,1,,uy,0
dl,5,,uy,0
dl,9,,uy,0
lsel,s,line,,3
lsel,a,line,,12
nsll,s,1
!FARE MANUALMENTE: solution-define loads-apply-structural-displacement-on nodes-all-uy
!!cp,1,ux,all
allsel,all
ldread,temp,,, , ,'dissipatore','rth',' '
finish
/sol
AUTOTS,1
TIME,1
SOLVE
aiace is offline   Reply With Quote
Pro/E to ANSYS Parameterization Guide Trues ANSYS 4 April 18, 2018 05:52
Can you help me with a problem in ansys static structural solver? sourabh.porwal Structural Mechanics 0 March 27, 2016 17:07
Ansys SIG$ILL error loth ANSYS 3 December 24, 2015 05:31
2-way FSI in Ansys CFX 15 LucasGasparino CFX 3 August 6, 2015 03:17
Exporting results from CFX to ANSYS ?? sohail ahmed CFX 1 December 20, 2007 01:10
