little CFX test
Old   May 16, 2009, 05:27
Default little CFX test
mauz is on a distinguished road
hello everybody,
in an homework regarding CFX I'm asked the following:
Laminar incompressible flow is modeled in a problem where an additional physical scalar φ should obey following equation:
φ'_t = Γ(φ''_x+ φ''_y+ φ''_z)
possible replies:
• It is possible to implement the model using CFX if Γ=Γ(x,y,z)
• It is possible to implement the model using CFX only if Γ is constant
• It is not possible to implement the model in CFX
I think first one is the right answer, I don't see any reason why it shouldn't be possible to implement a variable Γ in space, but probably the easiest solution is the wrong one ;-) Maybe some of you with more experience in CFX can give me reason of this limitation (if the right answer is not the first).
beest regards
mauz is offline   Reply With Quote
additional scalar, laminar flow, quiz
Pros and Cons for CFX, CFdesign, COMSOL Val Main CFD Forum 3 June 10, 2011 02:20
Importing solutions in CFX. Alphonso CFX 1 August 1, 2008 14:01
PhD using CFX Rui CFX 9 May 28, 2007 05:59
CFX 10's solutions differ from CFX 5.7's Atit Koonsrisuk CFX 4 July 26, 2006 11:59
CFX 4.4 installation problem Pandu Sattvika CFX 1 December 1, 2001 04:07
