Create moving mesh without simulating (CFX)
Old   July 19, 2010, 06:12
Default Create moving mesh without simulating (CFX)
spatialtime is on a distinguished road
Is it possible to let CFX calculate a moving mesh (pre-defined mesh deformation: wall boundary layer moving), without doing the time consuming simulation. I want to do this predictions, so I dont get negative volumes or bad mesh during my calculation, so I have to totally redo it. It would be great if there is a trick to just get the mesh for every transient timestep without the equations solved. So in CFX post I just can see the mesh for every time step without of course the velocity field or other parameters that have to be solved. Note: its just mesh deformation, without FSI.
Hope to hear you, even if its an idea. Thanks
spatialtime is offline   Reply With Quote
Old   July 19, 2010, 16:38
NickFL is on a distinguished road
spatialtime-
Yes, you can simply turn off the flow equations by using the expert parameters. Simply add this in your .def file and set each equation to false. This will solve a predefined moving mesh for the specified transient time. Unless your mesh is huge, this will be pretty quick and a good way to debug your model.
NickFL is offline   Reply With Quote
Old   July 22, 2010, 10:30
Default Help please !
Pavelistyj
Pavelko is on a distinguished road
Dear all ,
I was using Fluent and Gambit . Now I must to learn
ANSYS DesignModeler
ANSYS DesignMesh
ANSYS CFX
and I have a problem to get started .
I want to start with a very simple problem : LAMINAR STEADY STATE FLOW IN RIGID TUBE .
Do anyone can give me some tips , or send me some useful tutorials ?
I'll be grateful for any help !
Thanks a lot,
Pavelko .
Pavelko is offline   Reply With Quote
Turbulence model for CFX moving mesh songxguan CFX 7 June 28, 2009 21:05
Error: create mesh in CFX Ac-Joker CFX 2 June 11, 2009 06:52
Moving (structured) mesh Jesper CFX 5 February 2, 2007 03:43
hex mesh using cfx mesh. mehul CFX 3 December 12, 2005 22:06
Create the file of PROTEMP.PLOT during moving mesh xhliu1 Siemens 2 November 4, 2004 04:23
