Ansys Transient thermal message
Old   January 12, 2011, 07:22
Default Ansys Transient thermal message
simone
simox 2 is on a distinguished road
What's the meaning of this message?
*** WARNING *** CP = 5.117 TIME= 19:33:29
Element shape checking is currently inactive. Issue SHPP,ON or
SHPP,WARN to reactivate, if desired.
simox 2 is offline   Reply With Quote
Old   January 12, 2011, 11:25
simone
ok
13 people that visits the message, and another solution?
please help me
Old   January 12, 2011, 12:12
sac
sac is on a distinguished road
Originally Posted by simox 2 View Post
ok
please help me
It means the element shape checking is turned off presumably because the job is coming from workbench which does its own shape checking prior to sending it to the solver.
sac is offline   Reply With Quote
Old   January 12, 2011, 12:16
simone
thank you
this means that there is an error message, how can I possibly turn it on?
Old   January 12, 2011, 17:12
sac
thank you
No it is simply warning you that the solver is not doing the shape checking because workbench has done it already.
Old   January 12, 2011, 17:27
simone
perfect, thank you.
I ask you just only the last thing:
when i start the transien thermal analisis the maximum temperature, in the early steps of time, goes above the initial temperature that i have estabilished...it is insignificant!
i think that is possible that i have too penetration between the edges so it's a problem of convergence.
do you know were i can change the penetration parameters of my geometry? only in the original cad file?
I have seen in some forums that there is a command to do it but i don't found it in the ansys mechanical interface!
P.S. i use Ansys Workbench v12
Thank you very much
Transient Thermal Analysis in Ansys Workbench khurram1 ANSYS 0 November 22, 2010 02:40
single directional message transmit in parallel model su_junwei OpenFOAM Programming & Development 1 December 17, 2009 07:00
Transient Thermal Analysis with FSI Abduri CFX 2 March 27, 2009 02:47
Transient Thermal Stress Distribution Ijaz CFX 0 February 19, 2009 16:27
Error message in CFX-10 CFDworker CFX 2 October 12, 2007 07:23
