Applying pressure on deformed surfaces
Old   March 3, 2011, 21:05
Default Applying pressure on deformed surfaces
hussas
hussas is on a distinguished road
I have some problems in applying pressure on a suction cup model. I am beginner in Ansys and working on Ansys Workbench
  • I have one atmospheirc pressure acting on the outside of suction cup and from inside it is 0.1 unit below atmospheric pressure.
  • The effective force is the difference between the presuure on outside and inside time the effective area.
  • In order to apply the pressure on both the side in Ansys Workbecnh I select inner and outer face and apply the pressure mentioned above.
  • This diffenrce in pressure deform the suction cup and some part of the suction cup come in contact with the ground sp the effective area is reduced.
  • How should i now apply the force on the inside of the suction cup that only acts on the face not on the part which is coming in contact with the ground?
Any help will be much appreciated
Thanks
Hussain
hussas is offline   Reply With Quote
UDF to define or adjust pressure??? engahmed FLUENT 0 July 6, 2010 17:19
Pressure enigma. Sara Main CFD Forum 22 July 30, 2009 04:46
Pressure Condition sidd Siemens 0 April 2, 2007 09:31
FLOW AROUND A PLATE_NEGATIVE ABSOLUTE PRESSURE???? tania FLUENT 11 March 23, 2004 08:51
Hydrostatic pressure in 2-phase flow modeling (CFX4.2) HB &DS CFX 0 January 9, 2000 13:19
