March 6, 2012, 14:42 |
post-processing
Vitaly
Rep Power: 14 |
What I want to do should be very easy, but I can't find a way to do it. I have a specific surface with a WSS contour plot. All I want to do is output a txt file with the coordinates of each facet centroid and the WSS value at that facet. Any advice? Thanks, Vitaly |
March 8, 2012, 06:18 |
Max
Rep Power: 14 |
If you are using CFD-Post, the way I would use is:
- insert a plane at the location where you are interested in the WSS values - file --> export - under Locations, select the Plane and select the variables on the bottom... which would be X,Y,Z, and the Wall Shear values you are interested in |
March 8, 2012, 10:06 |
Vitaly
Rep Power: 14 |
Thanks for the reply...
That is I have been doing, but I would like to be able to loop over a face in a UDF and get the values so that I could use them in the UDF. Thanks, Vitaly |
Ansys Post processing | ano999 | ANSYS | 1 | May 27, 2011 16:24 |
NO model vs post processing in coal combustion,CFX | sakalido | CFX | 1 | April 15, 2011 14:07 |
post processing for KIVA | dirga | Main CFD Forum | 5 | April 23, 2009 10:58 |
Question about post processing | qtian | OpenFOAM Post-Processing | 0 | July 24, 2007 12:44 |
Post Processing in FEM | Abhijit Tilak | Main CFD Forum | 0 | April 26, 2004 11:59 |
