March 6, 2012, 07:19 |
Meshing suggestion for a newbie!
Rep Power: 14 |
Hi, for past few days I have been doing analysis of 3D slider bearings which look something like this in fluent using workbench 12.1.
Firstly I did analysis on plane slider bearings which was easy for somebody new to ansys mesh like me and results were in tune with standard results. The mesh method I used was automatic with edge sizing and mapped face meshes and the results were good quad meshes. But when I started doing my actual model which is a slider bearing with a rectangular surface texture on fixed plane, the automatic method no longer gave me better mesh . So I changed to multizone meshing it is working for some shapes(different textures), but when I change any dimensions of texture the same method which I applied previously would not work . I still can't figure out how to mesh these surfaces so that i can get a uniform mesh like the one without textured surface.Any suggestions would be of great help! P.S. the image i provided is just to give an idea the actual clearance between the moving and fixed surface is in microns for my problem which I guess is what not allowing me to mesh correctly Last edited by chandu143; March 6, 2012 at 09:59. |
March 10, 2012, 12:26 |
Rep Power: 14 |
I figured it out anyway if anyone had same problem I would be more than happy to share my experience just message me.
[ICEM] Hexa meshing of Wind Turbine blade. Help for Newbie please | federvo.mala | ANSYS Meshing & Geometry | 4 | June 8, 2013 03:19 |
Newbie to OpenFoam - meshing questions | monti | OpenFOAM | 2 | January 3, 2011 10:07 |
Best Meshing scheme for Cylinder | Nutrex | Main CFD Forum | 4 | July 29, 2008 11:03 |
Singularity of grid?Volume meshing vs face meshing | Ken | Main CFD Forum | 0 | September 4, 2003 11:09 |
Volume Meshing & Face Meshing? singularity of grid | ken | FLUENT | 0 | September 4, 2003 11:08 |
