May 24, 2012, 13:56 |
Messhing Issue in Star-CCM+
Rep Power: 16 |
Hi everyone;
I am using STAR-CCM+ and I am not able to get the good mesh in sharp corners of my model which is an external flow analysis. When I refine the whole mesh by reducing the base size value it could help up to certain level but at the same time the number of whole elements increased exponentially while the improvement in the getting the good mesh in sharp corners is just a little. So playing with the base size is should not be the key value for getting the good mesh in sharp cotners. Is there any specific parameter in Star-CCM+ to help to get the good mesh in the sharp edges of the model. Your comments are grealy appreciated. Moti |
May 24, 2012, 14:02 |
Rep Power: 18 |
If you are not using the surface wrapper, then you need to add feature edges to the sharp corners before meshing.
May 24, 2012, 14:15 |
Ryne Whitehill
Rep Power: 18 |
As kyle said, make sure you have feature curves marking these sharp corners.
Once you have them in place, you can put a custom mesh size on the feature curve itself, refining that area without affecting the other areas of the mesh. |
May 24, 2012, 17:16 |
Rep Power: 16 |
Thanks a lot Kyle & Ryne. It helped a lot.
[Commercial meshers] Using starToFoam | clo | OpenFOAM Meshing & Mesh Conversion | 33 | September 26, 2012 04:04 |
Fluent Vs Star CCM | firda | Main CFD Forum | 3 | February 26, 2011 02:51 |
[Other] StarToFoam error | Kart | OpenFOAM Meshing & Mesh Conversion | 1 | February 4, 2010 04:38 |
error in star ccm | maurizio | Siemens | 3 | October 16, 2007 05:17 |
[Commercial meshers] Trimmed cell and embedded refinement mesh conversion issues | michele | OpenFOAM Meshing & Mesh Conversion | 2 | July 15, 2005 04:15 |
