how does the ignition model initiate main combustion
Old   June 23, 2012, 14:32
Default how does the ignition model initiate main combustion
mepgzzi is on a distinguished road
Dear all,
Im using StarCD for GDI engine combustion simulation. I use EBU model for main combustion and select the numerical ignition as a spark.
My question it, how does the ignition model trigger the main combustion. As is stated in methodology, ignition is accomplished when a portion of the fuel at the spark is consumed. Apart from this, does the ignition has anything to do with the local air-fuel ratio? Are mass,momentum,energy equivalence considered between the spark cells and the chamber cells that enough energy should be created at the spark to trigger main combustion, or is the ignition determined only numerically from the mass of fuel burnt at the spark?
Thanks
mepgzzi is offline   Reply With Quote
combustion model in premixed combustion chamber wuyu FLUENT 9 February 16, 2018 10:40
Where to find the theory for weller flamet combustion model 21kalee OpenFOAM Running, Solving & CFD 7 December 19, 2012 17:18
I can not achieve ignition in combustion chamber. hectordiaz FLUENT 0 June 6, 2011 05:38
urgent: Combustion constant temperature Tim Siemens 3 June 29, 2008 18:12
Help about premixed combustion with BVM model Nena CFX 1 September 8, 2007 10:15
