Extrusion along a spline
Old   January 31, 2002, 09:42
Default Extrusion along a spline
tom
Hello, Can you help me? I am looking for a trick to made an extrusion along a spline with Prostar. Does someone have the solution? Tom
Old   January 31, 2002, 12:05
Default Re: Extrusion along a spline
steve
Use VSPGENERATE. That's exactly what it was made for. Steve
Old   February 1, 2002, 03:35
Lars Ola Liavåg
Hello there,
Using vspgenerate isn't all that intuitive since it only creates vertices. Here's a macro that I've been able to run successfully. With a little luck, it might make getting started a wee bit simpler for you...
Regards,
Lars Ola
! Macro that extrudes fluid cells from a set of shells and vertices along a spline (in the direction of ascending spline vertex nos.)
! Input variables:
*set,csex,7 ! cylindrical coordinate system
*set,typs,4 ! cell type for baseline shells
*set,typc,15 ! cell type for fluid cells
*set,spid,4 ! extrusion spline ID
*set,edis,1.0 ! extrusion distance (% of spline)
*set,ncax,40 ! axial fluid cell count
csys,csex
! Disconnect baseline shells from model and extrude ncax layers of fluid cells along the spline over a distance of edis.
cset,news,type,typs
vren,cells,,cset
vset,news,cset
*get,nvmx,mxver
*get,nvmn,mnvset
set,nvof,nvmx - nvmn + 1
ctab,typc,fluid,typc
vcextrude,ncax,nvof,cset,,,local,0,0,edis / ncax
vspgenerate,spid,ncax + 1,nvof,vset,,,perc,,edis,
cset,news,type,typc
cplot
Old   February 1, 2002, 08:08
Default TThe macro
tom
Thanks a lot for the macro. It worked succesfully for me as well. Regards. Tom.
[blockMesh] How to use the spline commands tnm23 OpenFOAM Meshing & Mesh Conversion 10 December 13, 2009 03:16
B Spline codes rahul garg Main CFD Forum 0 May 26, 2006 21:36
spline creation siva Siemens 0 March 2, 2006 15:51
3d spline interpolation Matthias Main CFD Forum 6 January 11, 2002 00:47
B-spline Method Peter Liang Main CFD Forum 2 September 3, 2001 07:14
