User viscosity routine and user scalars?
Old   July 21, 2002, 18:00
Default User viscosity routine and user scalars?
Jeff
Hi All
I asked this question in the general forum and someone pointed me to star-cd. As it turns out, I am pretty sure we have star at work so I would like to ask the same question here to confirm that I can do what I need to do.
I need to be able to model a non-Newtonian fluid and it will require a user subroutine. The problem would require standard arguments to the viscosity function like Temperature, strain-rate, etc.. but would also require the gradient of a user scalar variable, which is the solution to a Poisson equation. It would look something like this:
mu=mu(T, s-dot, |grad(c)|)
Can Star-CD handle this situation? Hopefully, I will get a hold of some manuals next week. Is there a specific section for me to look at?
Thanks Jeff
Old   July 22, 2002, 04:43
Default Re: User viscosity routine and user scalars?
Richard
STAR can handle this situation. The subroutine you need to use is VISMOL, but you'd need to contact your local CD-adapco support office to get help on incorporating scalar gradients into the subroutine. It's easy to do, but not without some help from a support engineer.
Old   July 22, 2002, 07:28
Default Thanks, I'll give them a call.(nm)
Jeff
Thanks
Old   January 6, 2003, 05:26
Alexander
Hi Jeff!
I have to solve the similar ploblem. The coefficient in the motion equation is governed by Poisson equation. After solving Poisson equation it is necessary to calculate the gradient of the scalar. What STAR technique would you suggest to use: a) to solve Poisson equation; b) to calculate the gradient (vector) of the scalar.
Thanks Alexander
user sub-routine Mac Siemens 0 November 27, 2006 22:42
CFX 10 User Sub Routine Claudia CFX 6 February 15, 2006 08:32
user sub Routine sam Siemens 2 June 11, 2005 12:37
user defined scalars shankar FLUENT 0 May 7, 2005 06:55
User CEL or Junction Box routine? Lexi CFX 6 January 22, 2004 08:52
