Problems with moving mesh
Old   January 23, 2003, 14:48
Default Problems with moving mesh
Valery Ponyavin
Hello! Sorry for bothering you. I'm new user of Star-CD. For solving my problem I need to use moving mesh. I use Star-CD version 3.15 for unix. First of all I performed tutorials 1..6. It was OK. But in time of performing tutorial 7.1 (2D transient flow with sliding mesh) I faced with a problem: After performing Pre-Processing(Prostar), Pre-Processing(pmovlink), and Analysis(starlink) I attempted to use Post-Prosessing(Prostar). But in time of opening transient post file Prostar gave out error (error opening file tut.pstt) because the file is not exist. Why the file is not be created automatically? I performed all of commands exactly as in tutorial. Maybe something wrong with performing pmovlink command because after the performing I didn't see any information on window except " New parm.inc, removing NCTMXD in starin.f Size of executable star=8.9517 MB "
Could anybody help me?
I attempted perform tutorial 11.1 - I faced with the same problem.
Thank you in advance
Truly yours
Valery
Old   January 28, 2003, 04:20
Default Re: Problems with moving mesh
Nicola
Hi Valery,
could it be possible that there is not enough disk space on your computer? Star is producing temporary files which take some space during calculation. Try to delete all old tut-files you don't need anymore.
Best regards,
Nicola
Old   January 28, 2003, 22:48
Valery Ponyavin
Thank you Nicola. I just found the mistake. Point is that STAR-CD cannot find the user1.so library. After changing the STAR-CD configuration (with the help of administrator of unix-system ) so that STAR-CD will be able to find this library in the future, STAR-CD works OK! I can perform the tutorials 7 and 11.
Motion diffusivity solver has problems with patches moving toward each other bfa OpenFOAM Running, Solving & CFD 2 July 8, 2009 21:35
Moving Reference frame - UDF - Moving mesh modisa FLUENT 0 April 18, 2008 13:31
'No response from HOST' error-Moving mesh problems Alfred Herman Siemens 1 June 15, 2007 06:53
Help for cut cell scheme for moving problems Wei Main CFD Forum 0 August 2, 2006 09:32
Restarting for problems with moving meshes Maya Siemens 2 October 4, 2002 03:51
