specific heat=f(temperature)-how to do???
Old   June 12, 2003, 09:06
Default specific heat=f(temperature)-how to do???
Micha
I would like to model the specific heat as a function of temperature. Therefore I calculated the specific heat of my gas-mixture at different points with an other programm, calculated the quotient Cp/R according to the manual and also fitted a polynom to these values (4th degree). So I got 5 polynomial coefficients.
I tried to define the polynom with command popcp (without the n+1 coefficient), but Unfortunately PROSTAR calculates the wrong values for the specific heat...!
Probably the reason is, that I have to define another coefficient for enthalpy (-->methology equation 1-41 or star-commands-help: popcp). Why do I need this one? Where can I get it from?
What do I have to do to define the polynom for cp=f(t) correctly?
Thanks for every advice!
Micha
Old   June 12, 2003, 10:21
Default Re: specific heat=f(temperature)-how to do???
m-hack
Try a Fortan code in the CONVTE.f subroutine. You define both enthalpy and cp there.
Greetings, Marc
Old   June 13, 2003, 06:29
4xF
Hmmm.. Quite tricky this one... The polynomial definition is set accordingly to the definition of H/RT used by the Chemkin database. The relation to be used corresponds to the following formula:
H/RT = Cp/R = C1 + C2 T /2 + C3 T^2 /3 + C4 T^3 /4 + C5 T^4 /5 + C6/T
So, you have to calculate your coefficients so that they match the definition above.
Old   June 13, 2003, 07:48
Micha
Hi 4xF,
I got a polynom for cp/R fitted with MS-Excel to something like Cp/R=a1+a2*T+a3*T^2+a4*T^3+a5*T^4 with cp...specific heat capacity and R...specific gas constant.
So according to you, I can't use this simple polynomial fitting, but I have to do another one which includes also the term: a6/T .
Then I have to calculate my values for PROSTAR like this: C1=a1 C2=a2*2 C3=a3*3 C4=a4*4 C5=a5*5 C6=a6
Is that correct?
I just want to make sure I got it...!
Thanks. Micha
Old   June 13, 2003, 10:07
4xF
This is correct, when you do it like that. You can set a6 to 0. if you want to. a6 should be used to calculate the reference enthalpy at T =298.15. For a pure specie, this value should give you a value of H/RT that is nearly 0.
specific heat and mean specific heat Duan J Q Siemens 2 November 20, 2007 06:59
specific heat grzesiek FLUENT 2 February 16, 2006 11:18
Specific heat Andrea CFX 1 May 30, 2004 01:55
specific heat in UDF gino FLUENT 3 November 22, 2001 23:16
Integral specific heat Steve Amphlett Main CFD Forum 0 August 25, 2000 09:51
