transient problem
Old   July 25, 2003, 12:46
Default transient problem
Alejandro H Rossette
Actually We are working in transient analysis of first stage Gas turbine Nozzle with Prostar.
I have a question in the way we want set the boundary conditions, this because we are working the input region with a table option (R=radial position of the blade lengt[mm], TEMP, DEN, V)I mean, the table contains 4 parameter R=independet variable, (TEMP,DEN,VElocity=dependent variable).
In the case of transient, I need another aditional table with a new dependent variable..the time, I want to set the boundary condition TEMP; DEN; VEL) depending of TIME AND RADIAL POSITION....HOW can I do THAT??
Actually I have results with boundaries depending of Radial position....But we need both independent variables (time and Radial pos.)
Another problem is a error message that appears : ERROR #211 *** INSUFFICIENT DIMENSIONS FOR THE CONDUCTIVITY ARRAY.INCREASE PARAMETER NCTMXC OR NBTMXC AND RECOMPILE. ?????I had increased this parameters in the parm.inc, but the problem still appears.....
Iīd appreciate any information yuo can give me...
best regards
Alejandro Hernandez Rossette
MEXICO
Old   September 3, 2003, 10:34
Default Re: transient problem
roadracer
Hi Why donīt you try with bcdefi.f user subroutine? Reagrding the parameters, you have to increase them from within prostar. Best regards Roadracer
Transient Problem Noureddine CFX 3 August 18, 2008 14:47
Transient problem! Jamesdclimber CFX 8 February 11, 2005 15:43
transient problem leo Siemens 3 February 13, 2003 01:28
transient problem susan Main CFD Forum 3 December 5, 2002 12:06
Transient Problem Sundar FLUENT 1 May 7, 2002 07:34
