Flow through solid cells
Old   August 29, 2003, 07:02
Default Flow through solid cells
Julie Polyakh
I obtain flow through the solid cells. How it may be avoided?
Old   September 6, 2003, 08:18
Default Re: Flow through solid cells
4xF
Can it be that you have changed the cell type in PROSTAR, but not written the geometry file before starting the calculation with STAR? Be aware that PROSTAR is also a preprocessor for STAR, so that model file and geometry file can contain different informations.
coupling solid and fluid cells?? kcg Siemens 4 March 13, 2007 09:39
Solid cells on symplane boundaries samu Siemens 7 May 29, 2006 10:07
Unresolved & Problem Cells of Solid Type Harry Siemens 1 August 2, 2005 15:11
Temperature profile in Solid cells pramod Siemens 3 May 30, 2005 13:56
Building solid cells kerem pekkan Siemens 0 November 21, 2000 17:47
