Negative volume
Old   September 15, 2003, 13:07
Default Negative volume
Mahbub
Hi, How can I get rid of the Error message # 70, " Cells found with negative volume or volume less than specified value"? Thanks a lot. Mahbub alo_90@yahoo.com
Old   September 15, 2003, 17:48
Default Re: Negative volume
allan
this error message means the cell has too small a volume. Are you using proam?
allan
Old   September 15, 2003, 18:09
Mahbub
Thanks. No, I'm using Prostar. How can I fix that? Mahbub
Old   September 16, 2003, 00:07
carno
Go to check tool and check the cells for 'left handed cells' criteria. Then click on the 'fix left handed cells' tab. and again check for -ve volume. It will definately solve the problem.
Thanks
Old   September 16, 2003, 00:22
Mahbub
Yes, the problem is solved. Thank you so much carno. mahbub
Old   September 16, 2003, 11:21
cfdweirdo
Be careful!!!
There are left-handed cells which are simply defined incorrectly.
There are also truely negative volume cells which are a cell quality issue.
Best thing to do is inspect the cells. Don't push buttons blindly.
Good luck.
Old   April 28, 2011, 01:39
abstrused00388@gmail.com
abstrused00388 is on a distinguished road
Originally Posted by carno
;165312
Thanks
Fix left handed cells ?? i dont find a tab like that .. ! sorry for being lame ..but please excuse me and let me know !
With Regards ,
SanZ
[I Will Have Plenty Of Doubts. So,
Send me Your Solutions Faster ! ]
abstrused00388 is offline   Reply With Quote
Old   April 28, 2011, 08:04
Robert
RobertB is on a distinguished road
The command is CFLIP, but it does depend on the cause. If they are extruded left handed, for example, this will work, If they are distorted then it ultimately will not.
RobertB is offline   Reply With Quote
Negative Volume in CFX Barbara CFX 2 January 10, 2008 10:19
Help: Negative Volume MANOJKUMAR FLUENT 8 December 24, 2005 04:59
negative volume Avesta FLUENT 2 June 19, 2004 06:34
Negative Volume sen Siemens 2 January 18, 2001 23:43
negative volume Sabatini Siemens 4 October 26, 2000 10:07
