Finite Heated Region?
Old   December 2, 2003, 21:25
Default Finite Heated Region?
Ethan
Hi, Consider a channel, at 0<x<a and x>b, the wall maintains a temperature To. At a<x<b, the wall temperature suddenly increases to T1. We would like to monitor the temperature at the downstream (x>b), does anyone know how to use starcd to model this ? Thanks in Advance. We really appreciate !
Sincerely, Ethan
Old   December 3, 2003, 12:09
Default Re: Finite Heated Region?
Ethan
Hi, Consider a channel, from 0 to L1 and L2 to L3, the wall maintains a temperature To. Between L1 and L2,the wall temperature suddenly increases to T1. does anyone know how to use starcd to model this (L1 less than L2 less than L3)? Thanks in Advance. We really appreciate !
Old   December 3, 2003, 12:39
Brian
You create three separate wall boundary regions and specify the temperature on each. Simple.
solving finite journal bearing problem by finite difference Atit Koonsrisuk Main CFD Forum 6 March 29, 2015 08:09
sliding mesh with Finite elements or finite volume tool Main CFD Forum 0 October 9, 2008 10:07
formulation of finite element&finite volume method ravindra FLUENT 0 June 27, 2007 12:04
Finite volumes vs. finite elements: applications Lionel S. Main CFD Forum 10 January 22, 2007 10:51
Finite volume or finite differene for free surface G N Xie Main CFD Forum 8 January 10, 2005 07:42
