Home > Forums > CD-adapco
Data size limit
Old   January 5, 2004, 12:23
Default Data size limit
Kaokanya
Hi! I couldn't run my job due to a problem with data size limit. Here's the warming message. "9434:./star-sofcc.exe: /sbin/loader: Fatal Error: Program datasize exceeds process datasize limit." I've tried running prosize and resizing my parameters for the param.prp file but still have the same warning message. By the way, the size of an executable star-sofcc.exe is 217.695 MB. I'm just wondering to what limit it should be. Thank you!
Old   January 5, 2004, 13:05
Default Re: Data size limit
steve
Its not a STAR or Prostar limit - its a problem with your environment. You need to have your system administrator raise the datasize limit either of the whole system or maybe just your specific account. If you type the "limit" command (its a unix command - not a prostar command), you will probably see that your allowed "datasize" simply is not big enough. You might try typing
limit datasize unlimit
to see if you can affect it yourself. If not you need to talk to the sysadmin.
Old   January 6, 2004, 08:32
Steve
Also be aware that if you are running on an HP, there is a configurable kernel parameter that controls the maximum datasize of ANY process. Increasing that requires "sam" and a reboot.
Thread Tools
Trackbacks are On
Limit on maximum cell size to minimum cell size ratio albcem OpenFOAM Running, Solving & CFD 2 October 17, 2011 12:00
title bar- change font size & data??? John FLUENT 4 July 4, 2007 01:01
Downstream droplet size data Nick CD-adapco 1 December 11, 2004 18:17
how can I reduce the file size of transient data Yuan-Heng Huang CD-adapco 3 December 1, 2000 22:16
Data needed- Size & Temp. Distribution of Spray R.Sureshkumar Main CFD Forum 0 February 15, 1999 01:59
