Problems with tut 7-3
Old   February 25, 2004, 07:47
Default Problems with tut 7-3
Bo Jensen
Hallo All
I try to do tut 7-3. I have used the prep.inp to generate the geometry and simulation set-up. Then I exit Prostar (win2000 machine) and the I run the simulation. However, it seems to halt at a point. In the DOS prompt I have the following:
*** Geometrical calcualations started *** Geometrical calcualtions completed *** End og evnt file reached: no more special mesh operations, except for "change grid" *** Executing promove.bat
And then nothing happens - I have now waited for 30 min or so...
Anyone got an idea??
Bo
Old   February 25, 2004, 17:01
Default Re: Problems with tut 7-3
Jörn Beilke
How many starsuites do you have? CD was very "nice" to us when they changed their licensing. If you want to run moving mesh with prostar you need two starsuites, because star and prostar run at the same time.
UDF problems Winnie FLUENT 22 February 29, 2020 04:32
Problems with Fluent on simple 1D problems agg FLUENT 3 November 21, 2008 11:55
problems Rogerio Fernandes Brito CFX 1 May 5, 2008 21:08
MPI PROBLEMS gtg627e OpenFOAM Running, Solving & CFD 20 October 5, 2007 04:02
UDF problems Paolo Lampitella FLUENT 5 September 8, 2005 20:43
