ineteger variables
Old   May 11, 2004, 14:11
Default ineteger variables
isidro
Hi, Why is it that sometimes when I calculate a variable in Posdat.f the result is given in integer numbers, even though it is a real number. Here is what I have: var(ip)=c1*t(ic,1)*log(abs(var2/c2)), where t(ic,1) is the relative temperature, c's are constants and var's are variables. Var2 is fortunately giving me good 'real' results. This should be giving me something around 0.9 but it sticks to 0 every time I call for it. Will appreciate any suggestions. Many thanks IM
Old   May 12, 2004, 04:53
Default Re: ineteger variables
CMB
Var in your problem must be defined with a name starting with a letter between i-n, these will always give you integer values, all the rest will give you real values.
Using ddt with different variables harly OpenFOAM 0 December 5, 2008 15:18
UDF for mean variables Gab FLUENT 0 September 28, 2007 16:17
CEL and Variables stex CFX 18 June 27, 2005 05:50
Variables in v3.2 Sheila Siemens 2 October 8, 2004 08:33
rp variables phil FLUENT 0 September 18, 2003 12:01
