-ve pressure
Old   May 28, 2004, 00:09
Default -ve pressure
carno
Hi All
I am doing one simple simulation involving pressure calculations. But my problem is that I am getting -ve abs pressures at zones where there are high velocities (region of small gap).
I have tried refining the mesh. (all tets). But still I fail to get good solution. Kindly guide. Fluid is water. Pressure difference at inlet and outlet is 60psi(~4bar).
What shall I do?
thanks
Old   May 28, 2004, 04:28
Default Re: -ve pressure
Jörn Beilke
Are you sure that your flow is non-cavitating in the reality?
Old   May 28, 2004, 08:27
carno
Thanks Jörn
Right now I have no idea, but I have restarted the run with reduced pressure differential. This is working fine. Slowly I will ramp the pressure to my desired value. Lets see. Velocities go around 24m/s for water in 0.25mm gap. (where I get -ve pressure)
Anyway, if the flow is cavitating, what is the option? Shall I solve it with cavitation model?
What type of pressure can give the pressure drop david FLUENT 1 February 17, 2014 11:51
Pressure driven laminar flow simpleFoam pressure higher at the outlet than inlet gabriel OpenFOAM Running, Solving & CFD 16 September 30, 2009 18:20
Forcing pressure outlet according to pressure prob Cedric FLUENT 0 July 29, 2005 11:49
pressure driven flow by pressure correction method justentered Main CFD Forum 0 December 29, 2003 23:52
Total pressure to static pressure ratio roadracer Siemens 1 April 17, 2003 05:31
